Monster MotorsportEM Tuning
Like Tree1Likes
  • 1 Post By StrmsekS3
Thread: 2002 S3 headlamp issues
    Nov 2007
    158
    So the drivers bulb went out on me a mnth ago, didnt get chance to change right away and it started working, now its just gone off again!
    so ive swapped the bulbs over, and its not the bulbs
    next up ballast?? or something else to check?
    audi just told me i cant buy the ballast seperatly and its £600 for the headlamp!
    so been looking for a bit more info on how difficult it is to change the ballast?? i dont think my local garage will be interested in this!
    ive found a few ballast units for about £100, but would also look at 2nd hand head lamps
    all information appricated! does anyone have part numbers for ballast, or headlamp
    cheers
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,272
    Have you checked the fuses yet? Each side has its own fuse. I had a dodgy fuse and ended up buying a new bulb only to find out I needed a new fuse.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Nov 2007
    158
    aye cheers seems like it was a fuse!! swapped it for the heated washer jets one and headlights all working! i thought because it had stopped at started it again it prob wouldnt be that but really should of checked it! cheers!!!
    Westy likes this.
    Nov 2007
    158
    ok so it seems my headlight is playing up again!!, drivers side dipped beam, have checked fuses, bulbs, scanned the car and found a fault with level sensor showing short circuit?? could it be the issue?
    any other ideas? due an mot very soon!
    cheers
    Westy's Avatar
    Dec 2008
    17,272
    Ballast?
    S3 Build Thread
    Nov 2007
    158
    Guys anyone quickly have an idea if a 2001 xenon headlight unit from an A3 will fit a 2002 S3?
    they look the same just wondered if anyone knew more
  1. 2002 S3 Headlamp washers
    By 86fran in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2012, 18:18
  2. 2002 A3 aerial reception issue
    By Byro in forum In-Car Entertainment
    Last Post: 17th July 2011, 18:45
  3. 2002 S3 - Headunit lights / Fuse issue possibly?
    By djarchive in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2011, 12:27
  4. 2002 A3 Headlamp Adjuster
    By soulsurfer in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th October 2009, 20:59
  5. 2002 S3 over boost issues
    By Redline1984 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th September 2008, 18:25
