Results 1 to 7 of 7
    sambryant's Avatar
    seat leon cupra r owner
    May 2011
    bristol
    158
    Anyone using aem boost gauge, I have issues.
    I have not long bought a electronic aem boost gauge but having issues. When I crank the car over the gauge cuts power and loses its saved calibration. Now with fitting you have 3 wires, ground, ignition and live.
    I have my ground wired into one of the ground points under the dash. Then I take the ignition from the yellow power point under the dash. The live from the live power point under the dash. To me this all seems correct.
    Why is it the gauge still switches off for a split second on start up? Idle reads 5psi due to the power issue.
    Help
    BADGER 5 TUNED gt2871, 360bhp 360ftlb
    Sep 2012
    West midlands
    368
    Quote Originally Posted by sambryant View Post
    Help
    must be a switched live mine does exactly the same did state on box will not calibrate properly without permanent switched live mines not aem though! Try diffrent live!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Try taking a temporary live direct from the battery and see if the issue persists... if it does then its likely an issue with the gauge itself...
    <tuffty/>
    sambryant's Avatar
    May 2011
    bristol
    158
    Thanks guys.
    Paul I was always under the impression that the Power point under the dash supplied a permanent live? There are 1 yellow point (ignition live) 3 red (tried all 3 with same issue)
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,389
    test with a multimeter dude, it's the only way to be sure.
    sambryant's Avatar
    May 2011
    bristol
    158
    Wish I had one.... Fail
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Thanks guys.
    Trying to eliminate any voltage drop issues you may have... it should be permanent under there but clearly there is something thats causing the gauge to have a wobbler... you don't drive the car much during the week IIRC? low battery voltage won't be helping... I have similar issues (although my battery goes dead after 3 days...) and I occasionally get a fault code pop up to do with low voltage...
    As Nick says... test with a volt meter but a wire from the battery is direct from source so will give you some ideas at least...
    <tuffty/>
  1. Boost gauge - using Torque/Android or DashCommand/iOS
    By Nogmeister in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2012, 10:18
  2. Boost gauge wiring using mirror adjustment as switch
    By sekenzo in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2011, 15:14
  3. For anyone considering installing Boost Gauge(s)
    By RyanS3TT in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2009, 12:11
  4. Anyone modified their air-vent to fit a boost gauge?
    By dickys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2006, 19:18
  5. Digital boost gauge
    By Mo-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2003, 23:42
