AH FabricationsVolks Autos
Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By superkarl
Thread: Local garage fitted new TIP and now problems :(
    Oct 2012
    Leicester (LESTA)
    57
    Bought a silicone TIP on monday from creationmotorsport in birmingham and finally got the local garage to fit it for me yesterday morning however, I think they've fitted the N75 & boost pipes in the wrong places as well as leaving two empty holes in the TIP where some pipe work should go
    Been going mad because I think the car is overboosting and then limps at 3/4k rpm as n75 is not correctly connected. Can someone please help me out if I upload the pics. I feel so crap and I don't know why I let such idiots work on my car!
    Dec 2012
    116
    take it back mate and say all thats wrong
    BENJAMIN's Avatar
    Mar 2011
    466
    Quote Originally Posted by MILF View Post
    Upload a pic and i'll tell you if its fitted incorrectly.
    Does indeed sound like you're hitting positive deviation limp, probably due to an incorrectly fitted n75.
    James TQ's Avatar
    Apr 2012
    Essex
    548
    My tip had a hole to many so I had to blank it off.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,441
    A garage you say? Go somewhere else mate.
    Oct 2012
    Leicester (LESTA)
    57
    (im pretty sure the little pipe as you can see to the right of the TIP is from the actuator on the turbo?)
    Oct 2012
    Leicester (LESTA)
    57
    If someone could post close up pics of their TIP installed or help me with the right connections, I'd be very grateful
    Engine code is AMK
    BENJAMIN's Avatar
    Mar 2011
    466
    The pipe connected to the right hand side of the n75 (jubilee clipped) should be connected to the black plastic piece that's in the tip (looks like its been cut down though).
    The small pipe from the turbo you have in your hand needs to be connected to the n75. If you remove the pipe that is jubilee clipped to the n75, you should be left with a short plastic pipe and a long plastic pipe on the n75. The longer pipe sits in the spare hole in the tip and the pipe from the turbo actuator goes on the smaller tab on the n75. It does however look like someone may have cut down the longer plastic pipe on the n75 for reasons unknown, try and identify if its been cut down as that would identify it being the longer one.
    I hope that makes sense. I've never seen a garage fit something with such incompetence.
    Oct 2012
    Leicester (LESTA)
    57
    Thanks Benjamin for your help. I'm going to try this in the next few minutes and see what happens.
    Oct 2012
    Leicester (LESTA)
    57
    Quote Originally Posted by BENJAMIN View Post
    Is this right pal
    Picture 3 shows a pipe into the TIP. This is where I pressume the part which broke should have gone right? BTW rang Audi and they said I would have to wait 14 days for that little part so I bodged it as you can see for the time being.
    This is what I've done
    Can someone please please tell me if this is right or explain to me in the simplest way possible as I getting really annoyed now! I went back to the b@stard garage and they said that the guy who worked on my car isn't there today and should be back monday :@ what a **** up
    BENJAMIN's Avatar
    Mar 2011
    466
    Looks like you may have 2 pipes the wrong way round, tricky to see as someone's been in there chopping things around.
    swap the pipe that goes to the turbo actuator with the side that's sits in the tip. That should see you right. Faults may need erasing after you've got it correctly plumbed in.
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    145
    What does it matter if the same guys in? Surely the last thing you want's the muppet who made that poor attempt getting his hands back on it, even if he'd been in. I'd have wanted someone else doing it if I was in your shoes.
    At least it sounds like you're on route to getting it sorted now. I guess it shows how some mechanics are just doing it as paint by numbers, and don't actually understand how what they're working on works. Gladly it's not all of them, but you've got to be careful, just because they're a 'pro' it doesn't mean they actually know anything.
    1.8 20v turbo converted '88 Scirocco - ASN Build Thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    That is insane!
    Big Bang Yam likes this.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,064
    Which garage was it out of interest, are they a specialist or just someone at a garage that said they would give it a go?
    Aug 2012
    33
    It comes to something when a garage can't even fit a bloody pipe properly, Jesus. It's only a 20 minute job!
    Take it back out of principle, don't be fobbed off & definitely don't let the first idiot work on it again.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,327
    that's absolutely disgusting! Whoever fitted that hadn't got a clue, and if that unattached pipe in the first fwe pics was from the actuator, then they've left your car in a state that's VERY likely to blow it up very quickly!
    Cannot believe a garage has let that go out like that. Massive lack of understanding of some very simple stuff.
    Also, why is it so oily and dirty already? that's absolutely unacceptable for a garage to fit a brand new product and leave it in that condition.
    morons. demand your money back, find someone on the forum who can fix it all for you!¬
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    wow, from those pictures am I right in thinking that the garage broke the return feed from the charcoal canister so plugged it into the N75 instead? leaving the broken end of the original connection still sitting in the TIP and then leaving the spare hoses for the N75 disconnected meaning the turbo was revving its nuts off!?..... go tell the garage they are a bunch of **** wits
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Gizmo20VT's Avatar
    Jun 2012
    289
    I hope this can help you out. My paint skillz need work :P
    And your N75 layout, Long piece in the tip, opposite side to the turbo actuator. the remaining nipple 90" is connected to your boost pipe.
    Dec 2012
    bridgend wales
    51
    i was going to get a local garage to fit a new tip to my s3 but i decided to take it over to badger 5 at least you know the work will get done properly over there after reading this i am glad i made the decision. hope you can get this sorted
  1. Replies: 23
    Last Post: 21st July 2012, 20:58
  2. Massive Thanks to AMDessex, supply and fitted new Shocks and springs.
    By DJM1982 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st March 2012, 09:20
  3. Newbie - Just fitted aftermarket headunit and now no central locking!
    By Stanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2010, 10:27
  4. Replies: 5
    Last Post: 18th January 2010, 23:36
  5. Retro-fitted rns-e and now have flat battery!!
    By foolish3uk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th February 2009, 21:28
