Results 1 to 8 of 8
Thread: Gear changes?
    Sep 2012
    West midlands
    368
    Gear changes?
    Does any one know of a gear box that fits s3 or anyware that can fit like a rally gear box were gears are changed by forwards movement too go up gear and back too drop down a gear I've seen one fitted too an s3 on YouTube a lot quicker changes?????
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,624
    Get a short shift kit
    Select Vehicle - JBS otherwise get a dsg
    Lewis583's Avatar
    Mar 2010
    834
    If you want a fully sequential gearbox then you will have to contact someone like SQS or Quaife, but I hope you have deep pockets as they are mega money.
    The other option is the SQS sequential shifter which retains the standard gearbox. The sequntial part of this option is in the shifter as it just converts the squential shift motion into H-pattern by using a motor and a cam/wheel with slots cut into it. This still isn't cheap at approx. £1400 for the shifter alone
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Sep 2012
    West midlands
    368
    Quote Originally Posted by voorhees View Post
    have one of those already good bit of kit but I have seen an American s3 8l on YouTube using a stick like in a rally box just forwards for up gears back to drop down no side movement at all?
    Sep 2012
    West midlands
    368
    Quote Originally Posted by Lewis583 View Post
    so it's called a sequential box? Is this just forwards for up gear and back for down gears no side movement?
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,638
    Probably costs 3-4 the value off your s3. Then there's the regular rebuilds. Pointless unless you're racing and even then, only needed if you're chasing a few secs.
    The SQS shifter is probably the closest...
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    Sep 2011
    Isle of Man
    175
    I have just got bought a Sadev sequential gearbox for our race car was £8600, so not a cheap option for a road car.
    2000 Audi S3 Black. Engine rebuilt Wossner internals, custom map, B5 3" TIP, Haldex blue, sport shifter, H&R ARBs, Green filter, 8P gear knob, 18" RSTTs, K-sport 8 piston 330mm brakes Ferodo pads front & rear, Nitrac disc rear, AP coilovers, adjustable tie arms, Powerflex bushes all round, yellow mount, LCR splitter, 3" DP & decat, 006p & Liquid CUBE, Forge FMIC, 550 injectors, CR Hybrid Turbo Stage 4 and Custom manifold
    Audi S3 (310 bhp & 311 lbft)
    Aston Martin V8 Vantage
    CBR 600RR (08 )
    woody.dub's Avatar
    Jun 2010
    Essex
    98
    Gear changes?
    Both EUtuning and Oakleydesign do these shifters for stock VAG gearboxes and Porsches using electro magnets in the bottom of the shift tower
  1. 80 TDi "dead spot" on gear change
    By imported_JJlehto in forum Diesel forum
    Last Post: 11th August 2004, 11:52
  2. Short shift gear change
    By clcollins in forum Tuning
    Last Post: 23rd July 2004, 11:59
  3. Gear change / gearbox woes on new A3 TDI
    By jasew in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th June 2004, 18:29
  4. 0-60 times and gear changes
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th April 2004, 08:47
  5. 2nd to 3rd gear change grind/crunch
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2003, 17:20
