Volks AutosMonster Motorsport
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By millsy75
Thread: front mount intercooler
    millsy75's Avatar
    Dec 2012
    196
    Hi guys and merry Christmas!
    Car is booked in for stage 2 in January and I would like to have a front mount intercooler fitted at the time. I was looking at the forge kit but its expensive although there is a lot in the kit. Has anybody on here got one? Are they good or am I just paying for the branding?
    Does anybody know what power they're good for, i`m guessing the fit will be good. Any alternatives people can recommend?
    I want to keep the factory look and retain the fogs.
    Thanks guys.
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    The forge kit is fantastic. Easy to install and fits like a glove behind the bumper, giving the car a very oem look. Massively helps mid range power and air flow generally.
    Like you said, not cheap, but its a premium product and ready to go out of the box with no modifications necessary. I fluked mine on eBay for £450 with red silicone pipes to match the rest of my hoses...still one of my favourite bargains. Others being the brembo's.
    Power wise with the Intercooler?...probably as far as is possible. Other components would fail or be limited first.
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
    Jimgrim77's Avatar
    Nov 2011
    957
    And they look the business...
    millsy75's Avatar
    Dec 2012
    196
    Quote Originally Posted by Jimgrim77 View Post
    Thanks for your reply mate :-) Sounds good. I'm new to the scene coming from Evo ownership so I'm keen to get some more reliable power from the stock block!
    Can't believe you found one on eBay! I've convinced myself that will never happen! Ha ha
    Jimgrim77 likes this.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    The AH and wellycooler fmic are better.
    Cheaper
    Bigger
    Support more power
    Imo its a waste of ALOT of money.
    having said that, it meets jims and many others needs, it obv fits well, and supports around 300hp well.
    A wellycooler can be done for 200 quid though, and an AHfabrications for 350ish, and both support 500hp with great results.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Massive FMIC thread in the FAQ's in the stickies... Forge FMIC is fine for stage 1/2 but if chasing larger numbers later on you are better off with the AH v2 or welly cooler...
    Have a read of the thread in the stickies though...
    <tuffty/>
    Jimgrim77's Avatar
    Nov 2011
    957
    Agreed, it very much Depends on application.
    I picked up the forge one at a great price, no hassle to install and good results...I was never planning to go beyond 350bhp though.
    millsy75's Avatar
    Dec 2012
    196
    <tuffty/>
    Who sells the AH V2 and welly cooler?
    Many thanks.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    AH Fabrications and eBay respectively... this information is in the FMIC thread...
    <tuffty/>
    millsy75's Avatar
    Dec 2012
    196
    Think i've decided to go for the AH Fabrications V2 intercooler. Thanks for everybody's input :-) The car may be running bigger power in the future so I don't think the forge one rated to around 300hp will last me that long. Would like to have this mod done only once. When you go on the AH Fabrications website there is only 1 option for the S3, am I to take it this is the V2?
    I'm not handy with cars personally, more of a polisher! Would a normal specialist find this conversion easy or would I be better to speak to an exhaust specialist to do the job? (welding/making hard pipes) Thanks in advance
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Call them up to order the V2 (the "cossie core one"). They'll know. Get them to make sure the mounts are on the right way too.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    millsy75's Avatar
    Dec 2012
    196
    Quote Originally Posted by Sam_ View Post
    Thanks Sam, when I ask them to make sure the mounts are put on correctly what do I need to say to them? Should the mounts be pointing the opposite way to the pipes? Thanks, bit worrying that its often done wrong!
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Yeah, the opposite direction. Check the mammoth thread for details. Lars said he updated the jig so it should be ok but worth checking again.
    millsy75's Avatar
    Dec 2012
    196
    Thanks for that, I've read the thread a couple of times but I found it that long I started to forget what I'd read and what I hadn't! Ha ha
  1. Piping up a Front Mounted Intercooler (URS6)
    By smogthemog in forum Tuning
    Last Post: 27th December 2006, 17:40
  2. Front Mount Intercooler
    By Platinum70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd September 2005, 14:20
  3. Front Mount Intercooler
    By ashacre in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2005, 10:48
  4. Front-mount intercooler???
    By sport99quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th November 2004, 06:03
  5. S3 front mount intercooler
    By martin3310 in forum Tuning
    Last Post: 14th May 2004, 09:12
