AH FabricationsEM Tuning
Results 1 to 19 of 19
Like Tree2Likes
  • 1 Post By karl210
  • 1 Post By S3Zek
Thread: Just sheared a dogbone bolt
    Aug 2012
    34
    Angry Just sheared a dogbone bolt
    bit of a crisis - I have sheered off one of the bolts that connects to dogbone mount to the tranny whilst trying to replace the bushing.
    im probably going to take it to the garage to get the bolt removed and retapped but I thought id ask if im ok to drive whilst its only being held in place with one bolt now.
    annoyingly im up in leeds for xmas and my local garage is down in london.
    anyone know any good independant audi garages in leeds so I dont have to take it to a halfrauds.
    May 2012
    Manchester
    229
    i did the same when i replaced mine a few weeks ago and its holding up fine so far
    Tripp likes this.
    Aug 2012
    34
    ur only on one bolt still?
    ive stopped work on the mount, dont want to risk shearing the other bolt removing it, so the bushing will have to wait for now
    May 2012
    Manchester
    229
    yeah just 1 bolt tightened back up nicely and the other one got half tight and started to thread so i just left it in there like that
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    The bolts do not sheer in the subframe, only in the mount.
    If you sheer both of them you can smash the mount free and undo the bolts with vise grips.
    I quite often say I'm going to do things.
    Then never do them.
    May 2012
    Manchester
    229
    i think he means where it bolts to the gearbox. the 2 inline bolts
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    He'd be doing well to sheer them, they're pretty big bolts. Fair play if he has.
    It's very common to sheer the ones in the subframe, because of the ally mount corroding onto the bolts.
    Then never do them.
    Aug 2012
    34
    Quote Originally Posted by 16Klappe View Post
    You are correct, I have sheared the bolt connecting to the sub frame (the smaller ones, my mistake)
    As 16Klappe says I think it has sheared in the mount itself so I may attempt to remove the other bolt and grab the sheared bolt with vice grips.
    anyone know the type of bolt so I can buy a new pair to fit.
    cheers
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    Mine are held in with driveshaft flange bolts, M8 thread.
    Then never do them.
    Aug 2012
    34
    ok cool, is there any particular length bolt I need? may actually ring local audi centre and see what they have
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    I would say 60mm ish.
    Then never do them.
    Eddie S3's Avatar
    Jul 2011
    Aberdeen
    108
    I did the same to mine, blow torch and vice grips got it out for me
    Aug 2012
    34
    UPDATE: spent 3hours banging and spraying with penetrating grease and prying with a screwdriver (only thing narrow enough) today and finally removed the mount from the corroded bolt.
    annoyingly i was able to undo the rest of the bolt with my fingers - it was heavily rusted and I was worried the threads would be too damaged for the new bolt but its all installed and torqued up and everything seems good.
    I can feel the difference to responsiveness - yes there is a bit more idle vibration but I expect that to fade over the next few weeks.
    cheers all
    S3Zek's Avatar
    Sep 2011
    407
    This was mine.....was a right f***er....
    S3_OL likes this.
    Aug 2012
    34
    ^^ouch - that puts things into perspective...
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    I did the same thing the other day tightening up the mount to the gearbox the front smaller bolt wouldn't tighten, took it back out and the good news was its threaded its self, so gotta re tap it now grrr. Thought it was going too good as it only took 15 minutes to do
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    Mar 2013
    Fareham, UK
    82
    I just did the same thing... can anyone who had the same problem shed some light on where to get hold of the right bolts? Audi dealer best bet? or any garage?
    May 2012
    Staffordshire
    71
    Quote Originally Posted by olibattman View Post
    Pretty sure they're only an M8 bolt, as long as its the right grade and length you can get them from any garage really, although from audi you will get the exact one
    S3.2
    Mar 2013
    Fareham, UK
    82
    Quote Originally Posted by S3_OL View Post
    OK thanks, i'll ring around tomorrow...
  1. Just hit 50 users!
    By Jon in forum General Chat
    Last Post: 30th March 2012, 08:44
  2. Dogbone mount bolt keep turning
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th February 2012, 19:49
  3. Audi S3 Dogbone Bolts
    By djx11b in forum Parts Requests
    Last Post: 21st November 2011, 12:58
  4. Just bought some Wheel Spacers but now I need bolts.
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2010, 23:08
  5. Engine won't run after mounting bolts sheared :-(
    By VaulterTim in forum General Technical / How To
    Last Post: 11th July 2007, 12:39
