EM TuningChris Nott
Page 2 of 2 FirstFirst 12
Results 41 to 77 of 77
Like Tree17Likes
Thread: How does a s3 with 300/330bhp+ compare to e46 m3
  1. #41
    Sep 2011
    Isle of Man
    175
    They both feel rapid and over the same derestricted road cover ground very quickly, as has been said though once it gets to the higher speeds the S3 would have lost out. On the mountain mile I would have regularly seen 145mph in the M3 whereas the S3 is running out of road by 135-140mph. I had the SMG "2" box in mine and the gear changes were much quicker than anything I can manage in the S3 which will of had a bearing on things also.
    Westy likes this.
    2000 Audi S3 Black. Engine rebuilt Wossner internals, custom map, B5 3" TIP, Haldex blue, sport shifter, H&R ARBs, Green filter, 8P gear knob, 18" RSTTs, K-sport 8 piston 330mm brakes Ferodo pads front & rear, Nitrac disc rear, AP coilovers, adjustable tie arms, Powerflex bushes all round, yellow mount, LCR splitter, 3" DP & decat, 006p & Liquid CUBE, Forge FMIC, 550 injectors, CR Hybrid Turbo Stage 4 and Custom manifold
    Audi S3 (310 bhp & 311 lbft)
    Aston Martin V8 Vantage
    CBR 600RR (08 )
  3. #42
    Dec 2011
    630
    Quote Originally Posted by Hammy999 View Post
    yeah we can't compete in the gear changing times to likes of smg,dsg
  4. #43
    Nov 2012
    Dorridge, Solihull
    25
    Off the mark the S3 would have the edge but as you get close towards 100mph the M3 will make up the ground no problem, I've owned a CSL and that was brutal with it having around 20hp, 30lbsft increase and around 150kg lighter than a stock E46 M3 although I have been in a fair few E46 M3's personally in my experience you would need upwards of 350hp to embarrass an M3 due to transmission losses.
    Regards
    John
  5. #44
    Dec 2011
    630
    Quote Originally Posted by JMB-S3 View Post
    Regards
    John
    Are the transmission losses big in a s3 as is it not just fwd till they slip then power go's to the rear so not a permanent 4wd
  6. #45
    colicabcadam
    mid range torque means **** all when you are using the higher end of the rev range, let's face it, ragging it you'll spend most time between 6000 and 700 rpm
    an e46 m3 weighs 1550kg an s3 8l weighs 1450kg , that the weight of one really heavy guy, so it;s actually not much at all
    my money is on the m3, if you are beating the m3 i'd say it's due to the fact the m3 is in the middle of it's rev range as you've caught it off gaurd
    remember, the s3 has to spin 2 diffs, a haldex unit, 4 drive shafts and a propshaft, the m3 only neds to spin a propshaft, 2 drive shafts and one diff
    as for a k03s beating an e46 m3 - video ? because there's plenty of videos on youtube of m3's smoking 18.t in a mild tune !!
  7. #46
    colicabcadam
    Quote Originally Posted by Goubo1 View Post
    S3 8l mtm turbo conversion 330bhp - YouTube
    My s3 accelerating on a private road,how do you's think it would compare to the m3
    IT WILL LOOSE
    you have a LOT of lag there lol - 13+ seconds from 100 - 200 kph AND you had a run up to 100 kph !!
    M3 E36 3.2 100-200 - YouTube
    e46 m3 does 100 - 200 in 11 seconds, he started accelerating on 100 kph !
  8. #47
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Nothing better than the unity we have on this forum lol
    colicabcadam - I'm sure there is 18T getting beaten by m3,not denying it. I'm juat talking from personal experience.
    I never said I would wipe the floor with a m3. Just from 0-100 I've never been passed by one. Like I said before,um sure it would be different from 100+
    Goubo1 likes this.
  9. #48
    BENJAMIN's Avatar
    Mar 2011
    471
    I've just bought an e46 M3. I used to own a 400bhp s3.
    A 330bhp s3 is probably very similar in straight line performance. Handling wise, the m3 is very planted as it was always designed to have 340bhp, not 210.
    Loved my s3 as it was epically fast, but the m3 is such a competent package straight from the box.
  10. #49
    Dec 2011
    630
    Quote Originally Posted by BENJAMIN View Post
    A 400bhp s3 would that be around 300bhp/ton ?
  11. #50
    BENJAMIN's Avatar
    Mar 2011
    471
    Approx 270bhp per tonne
  12. #51
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,547
    Personally I think turbo lag on larger turbo'd small capacity cars is largely irrelevant if you drive it right... all this 5th gear from 30mph nonsense will always favour the higher capacity NA engine or smaller turbo'd small capacity engine...
    Anyone who drives a BT car properly knows which gear to start off in and a 400hp S3 is an animal off the line....
    Granted they handle a little like a blancmange but a BT car once going is not laggy at all when driven right...
    <tuffty/>
  13. #52
    Dec 2011
    630
    <tuffty/>
    I totally agree with you on that
  14. #53
    BENJAMIN's Avatar
    Mar 2011
    471
    I quite liked the lag on mine. You could drive it slowly off boost, or like a complete nob on boost.
  15. #54
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,547
    Amen to that... when I had a K04 it felt almost too 'willing' when driving normally... the BT is a lot easier to drive personally and gives me the best of both worlds... sensible off boost and mental on it...
    <tuffty/>
  16. #55
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,272
    I've not even come face to face with an M3 in my S3 so I can't compare but I've been in a fair few and I don't fancy my chances much.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  17. #56
    BENJAMIN's Avatar
    Mar 2011
    471
    http://i214.photobucket.com/albums/c...f/873fae05.mp4
    My S3 on 1.65 bar boost. 60-90 is pretty swift.
    edit- not sure if the video link is working?
    edit- fixed?
  18. #57
    Lewis583's Avatar
    Mar 2010
    870
    Not working for me Ben
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
  19. #58
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,466
    <tuffty/>
    love how mine drives even with the lower compression but it does help been a 2.1 I can say that i think it drives better than a 1.9 Saab 150 TDI in low revs that i drive often and that feels very flat.
    With the S3 i toddle round town happily at around 2-2.5k rpms, Nice chunk of torque at 4k as the turbo is producing boost and at about 4500-4800? its hitting full boost pull all the way to 7800, shift into the next gear and your still in the rev band ready to hit warp speed
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  20. #59
    Dec 2011
    630
    edit- fixed?
    thats pretty impressive mate anymore links ??
  21. #60
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,547
    oooo ooo ooo.... I have one...
    <tuffty/>
    Goubo1 likes this.
  22. #61
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Wish i could contribute
    I saw an e46 today, god they age well
    Goubo1 likes this.
  23. #62
    Nov 2011
    215
    I came across a 911 GT3 once in a mildly tuned classic Subaru. We had a bit of fun on some back roads and guess he had more to lose than I did, lol. We then came to a set of red lights in a village on the edge of town. When the lights went green we both nailed it and I got a better start than him (he was in front). There wasn't much in up to 60. Then between 60-70 onwards he just f@@ked off into the distance. When we where in town at the next round about I had a big grin on my face and he wouldn't look at me. It's all about then fun!
    I've spent time in a stage 1 S3 and E46 M3, all be it along time ago. It's like comparing apples and pears.
  24. #63
    BENJAMIN's Avatar
    Mar 2011
    471
    My new one. Fap fap fap.
    Goubo1 likes this.
  25. #64
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,782
    Very nice. Would only look better with clear indicators
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  26. #65
    Nov 2011
    215
    I wonder what they're up to with that Caddy in the beck ground?
  27. #66
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    <tuffty/>
    Tuffty what's that in your vent.....? Is it Liquid gauge...?
  28. #67
    Dec 2011
    630
    <tuffty/>
    what bhp is you're s3 making ?
  29. #68
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,547
    Quote Originally Posted by cecilthesausage View Post
    Yes...
    Just over 400hp although this video was done on an early map...
    <tuffty/>
    Goubo1 likes this.
  30. #69
    Reesy's Avatar
    East Sussex
    3,604
    I agree with what the bigger turbos drivers say, very easy to drive off boost and as mentioned lag isn't really an issue. If you want to put your foot down you may get lag in 1 gear if you are lazy, then you get lots of power in every gear.
    When I get back in the new year I will be able to answer this thread properly by overtaking Ben in his bimmer..
  31. #70
    BENJAMIN's Avatar
    Mar 2011
    471
    Quote Originally Posted by Reesy View Post
    But your car will still be a 5 door, denim blue, a3. I'll still be in an M3. Lol
    Westy and StaceyS3 like this.
  32. #71
    burns3's Avatar
    Jun 2011
    223
    When Welly first took me out in Bumble before buying her she reminded me more of my old hondas I had in my younger years than my other s3. Having a BT is like having the best of both worlds in my opinion so like vtec but with a hell of a lot more kick.
  33. #72
    Reesy's Avatar
    East Sussex
    3,604
    this is also true.
  34. #73
    Dec 2011
    630
    Driving home from Kilmarnock tonight and came across a z3m coupe and i believe they have the same engine as the e46 m3.the z3m coupe is from the same town as me never knew till I seen the driver,we came up to a roundabout around it and took the slip on to the private road.i was at 70 mph in 4 th he was behind and I heard him down shift then he just planted so I did the same by the time I got going it was level at the start but the big effortless push of torque and holding 4th till the red line I had a cars length on him by then so straight into fifth foot to the floor and I was just pulling away all the time even up to speed when he would have hit his limiter so I was pretty happy with that
    does anyone know how a z3m coupe compairs to the e46 m3 ??
    I can't wait to get a m3 to go for it
  35. #74
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    147
    e37 Z-coupe: 1450kg, 317bhp = 218.6bhp/ton, 0-100kph = 5.4 seconds, standing km = 24.4 seconds
    e46 M3 (2000): 1570kg, 338bhp = 215.3bhp/ton, 0-100kph = 5.2 seconds, standing km = 23.7 seconds
    Z-coupe's better power/weight, but the M3's slipperier. (drag coefficients of 0.37 and 0.33 respectively)
    S3 (2002): 1423kg, 221bhp = 155.3bhp/ton, 0-100kph = 6.6 seconds, standing km = ?
    Aero wise the A3's actually very evenly matched to the M3, no real aerodynamic reason the M3 would get away more at high speed, I guess the frictional losses though the 4wd might start causing some noticeable drag at high road speeds though?
    S3: 0.335 Drag Coefficient, 2.06m^3 Frontal Area, CdA = 0.69
    M3: 0.330 Drag Coefficient, 2.09m^3 Frontal Area, CdA = 0.69
    (Figures all taken from Carfolio.com, not sure on accuracy but it's always been good for me in the past)
    1.8 20v turbo converted '88 Scirocco - ASN Build Thread
  36. #75
    Dec 2011
    630
    Quote Originally Posted by RobinJI View Post
    e37 Z-coupe: 1450kg, 370bhp = 218.6bhp/ton, 0-100kph = 5.4 seconds, standing km = 24.4 seconds
    In this it says the z coupe has 370bhp that ain't right
  37. #76
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    147
    Yeah, that was just a typo on my part, meant to write 317bhp, not 370bhp.
  38. #77
    Dec 2011
    630
    haha sound I was thinking surely not got that power as he would have wasted me lol.dont look like their is much of a difference between then z3m coupe and e46 m3
  1. How does the Mk V Golf R32 compare to the S3 ??
    By Jimmy Parko in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2011, 12:35
  2. How Does S3 Feel Compared to a R32 ?
    By Yaks in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th April 2010, 18:58
  3. how does the a3 3.2v6 compare to mk5 r32?
    By p1tse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd March 2009, 22:47
  4. How does one tinker with one's motor???
    By S3BeemerBeater in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2004, 15:05
