    Dec 2012
    2001 audi s3 brake problem
    Hi All,
    Greetings! I just got a 2001 audi s3 8l and I love it! Especially it is my first car!
    But I have few problems about the brake:
    1. The responsiveness and the strength of the brake seems not very good --- I have to depress the brake deep down in order to feel the brake start to engage. I was told by the garage that the piston head on the calliper may be wear and need to be replaced (but sounds like he is not very certain...) Does anyone had the same problem and what could be the possible cause?
    2. The brake light on the rear keep failing.... What could also be the problem? In the sticker of the forum, I read something about the brake sensor can cause this problem over and over.
    Many Thanks in advance!
    Thanks,
    Noel
    Dec 2012
    7
    Well I'm not entirely sure but I would start by bleeding the brakes as you may have some water in the system, next if that doesn't work you may have a sticky calliper slider. It could be rusty or jut sticking. I would take them out and cleaned and grease the pin and where it locates. Or you could have sticky pads.
    I think generally it could just bee that you need to clean and grease all of your brakes and give them some fresh brake fluid.
    If that doesn't sort it then long travel could mean that your master cylinder has failed internally.
  1. 2001 Audi A3 electrical problem
    By Mr.Edgar in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2011, 18:10
  2. Audi S4 brake pressure sensor problem, 01435.
    By antboo1.8t in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th July 2011, 20:08
  3. audi 100 avant s4 1996 braking problem
    By manji in forum Classic Audi Forum
    Last Post: 6th January 2011, 17:46
  4. Audi A3 2.0 TDI Sportsback. Brake problems
    By les1982 in forum The Welcome Section
    Last Post: 7th May 2010, 12:36
  5. Audi A4 B8 brake problems.
    By SoSlow in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 4th September 2009, 15:53
