AH FabricationsJMB Retrofits
    Jan 2012
    26
    Audi A3 8l 2002 heated mirrors retrofit
    Hi,
    my car(a 2002 A3 1.8T) didn't had heated mirrors from the factory and from what I read it was just a plug and play job to upgrade to them. I checked to see if the wiring was present in the mirror casings and afterwards I ordered a pair of non-OEM heated glass, but after I installed them they didn't worked. I checked fuse no.1 and it was ok, but there wasn't any voltage coming to the fuse. I tested them in multiple days with outside temperature varying between -5C to +8C. The rear defroster is working. Any ideea what I'm missing? Should there be a relay for heated mirrors? Is an adaptation needed via Vag-Com(maybe for the Auto-AC; ch.46Central Conv. is not available on my car) ?
    Thanks!
    Mar 2013
    53
    Hi,
    Did you ever sort this out? Ive got a 02 a3 1.9tdi se and was wondering how to do it.
    Thanks in advance.
    Aug 2007
    199
    I did this a few years ago on my 02 S3. Even though the cabling was present in the housing for heated mirrors and through the door I had to run a cable from the fuse box to each side pillar (if I remember correctly) as that's where the cable ended. I think I used a wiring diagram from Elsawin (?) to confirm the mirror housing wires.
  1. heated mirrors retrofit...
    By demus in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th December 2012, 17:26
  2. A3 8L 2002 Heated door mirror glass.
    By Woody001 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2010, 22:06
  3. Audi A3 Heated Seats Retrofit Anybody???
    By EvolutionV in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th March 2010, 15:03
  4. Heated mirror retrofit
    By jsh in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th February 2010, 09:21
  5. 2002 A4 HEATED MIRRORS
    By noddy tt in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th March 2009, 17:42
