    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    random misfire/judder
    car has started to play up over the last 2 days
    it will randomly judder. feels like a light misfire. when i come onto boost it will judder then after about 4/5 seconds it will be fine. no fault codes/EML
    going to start with replacing the plugs (done about 12K on current plugs bosch super 4's)
    engine: AGU
    with it being xmas haven't got a massive amount of spare cash at the moment. so don't want to go replacing random bits for the sake of it.
    been looking around online seems like the ignition amplifier seems like this comes up alot when searching for misfires on the 1.8T lump. would this be a good place to start after plugs ?
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    stuck new plugs in made no difference.
    tested the ignition amp using this guide
    AudiWorld Tech Articles
    got around 200 ohms on all 4. so doesn't look like its that.
    coils ?
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,641
    Coilpacks are the most common issue if a misfire on the engines. Coilpacks can be tempremental so advice is to change them.
    Oke Phill's Avatar
    Mar 2012
    147
    Quote Originally Posted by Gops View Post
    +1 for sure!
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    899
    Add Vex182 on Facebook
    Agree with coilpacks, you did not use Super 4s again did you? NGK all the way! I melted a set of super 4s and Badger5 say they don't get on well with those plugs too.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Sep 2012
    Colchester
    90
    With misfire issues start with coilpacks
    if they are fine (tested by swapping them around to see if the misfire changes cylinder), then check spark plugs and the coil pack loom.
    If its spark plugs they will be coaked up with black soot or have evidence of arcing between points. Dirty brown colour is fine and normal.
    Loom is easy - if you have splits and can see exposed wire its either knackered or will be giving you more issues soon. You'll need to keep tracing back along the loom until the splits stop, and then solder a replacement loom in. Sounds scarey but its easy if you take your time.
    If all above is fine check vacuum lines - youll hear a hissing noice while engine is running. Thats a vacuum leak.
    Check boost pipes
    If its none of them and vagcom isnt helping the you'll need to check your compression.
    It going to be either be piston rings (blue smoke from exhaust?) or head gasket (white smoke from exhaust, mayo like substance on oil filler cap/dipstick, coolant level going down).
    A compression test will help you here (search youtube) and a sniff test on expansion tank for head gasket (goto a garage)
    Following that above should help you solve an misfire issue.
    Audi S3 [AMK 1.8T]
    Mods:
    N249 Bypass
    Revo STG 1
    Rota Grid Drift 9.5J alloys
    AP coilovers
    PCV oil catch can (to atmosphere)
  1. Allroad 2.5 TDI Misfire/Judder Under Load
    By tekno_al in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd August 2012, 22:56
  2. s4 misfire/juddering
    By jutlis 3.0 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th January 2012, 20:00
  3. S3 with lumpy idle and random misfire on bank 1
    By JohnDudley in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2012, 08:05
  4. Random misfire a3 1.8t agu
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2011, 13:30
  5. Random misfire no.2 cylinder
    By raffik0 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st November 2009, 16:54
