EM TuningChris Nott
    Apr 2010
    Help, gearbox stuck in two gears which codes please?
    sady this afternoon my 2001 A3 Quattro decided she no longer wants to reverse, engine stalls under clutch yet no movement
    informed by AA dude its stuck in two gears, got in back to the local garage which ive used for a while
    asked the guy what the best solution is, he said get a re con box, but im lost with the engine codes
    ARY EVK EFY
    do i just need a gearbox for engine type ARY or does the box need to also match EFY ?
    found quotes for £400 who guarantee its correct fit, yet another for £320 but not 100% sure if it will fit
    many thanks in advance
    (i have tried an afternoon of google before posting)
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,431
    ​Your engine code should be on your v5 document. x
    Lewis583's Avatar
    Mar 2010
    870
    If you look under the boot carpet or inside your service book, you will see a sticker similar to the image below.
    On the image below I have circled where the engine code and gearbox codes are listed.
    Use the ones from YOUR sticker when sourcing a gearbox.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
  1. replacement gearbox, which codes?
    By KB in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2011, 10:01
  2. Help with codes please
    By addamsmith in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th June 2006, 09:19
  3. VAG error code. Please help.
    By moschino in forum General Technical / How To
    Last Post: 11th April 2006, 20:34
  4. radio codes? please help
    By NxJxHxCedge in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th August 2005, 15:16
  5. Help with a part code please?
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2004, 16:48
