JMB RetrofitsBadger5
Results 1 to 13 of 13
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    Miniature video camera / mounts? Anyone have one and can recommend?
    I'm looking for a clever solution to record driving, driving incidences etc...whilst on the road.
    Have a friend who mounted a smart solution on his motor bike and it won him a fortune during an incident involving a car and I'm thinking along similar lines with the increasing numbers of idiots on the road.
    Nearly had an incident today and fancy 30 mins recording to and from work to minimise any chance negligence.
    Essentially, I use an iPhone as mobile and am not really sure whats out there.
    I'm open to any suggestion of mounting, and digital camera but would favour something discreet that I could leave in the vehicle 100% of the time and turn on/ off as required.
    I imagine a mount behind the rear mirror would be ideal and hope that someone can lend their experience if any.
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,277
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    I go on a lot of runs with people who use GoPro camera's.
    The quality is superb and I haven't seen any 'bad' recordings from them unless you don't fit them correctly.
    Wouldn't be able to say exactly what model is the best- but I suppose it depends on how much you want to spend on one.
    You got a budget in mind?
    May 2010
    Bedford
    2,877
    If descression wasnt an issue then yeah a Go-Pro is the best option always but that doesnt suit your requirements listed. Scott has one of the cameras that were advertised on the top banner on AS that he won. Quality seems alright and its small enough to keep in place 100% of the time
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,003
    Blackvue DR 380. highly recommended by me too.
    JSD 2.59
    Synergy-Solutions
    Jimgrim77's Avatar
    Nov 2011
    957
    Quote Originally Posted by kwistof View Post
    no budget...issue over cost/benefit and discretion really. Just don't fancy removing it all the time where not necessary. Thanks for heads up, will check go-pro as an option but will check the other ones recommended too.
    Jimgrim77's Avatar
    Nov 2011
    957
    Quote Originally Posted by sidibear View Post
    This looks interesting....
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    Have a look at mine here:
    http://www.audi-sport.net/vb/group-b...rotection.html
    Post 29
    I do think that Advanced are currently doing another offer on them, contact them for details.
    JSD 2.59
    Synergy-Solutions
    Jimgrim77's Avatar
    Nov 2011
    957
    Post 29
    great link, thanks. this looks right up my street.
    would like it installed though due to wiring issue.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Blackvue def the way to go for a permanent solution...Guess what the mrs has bought me....
    Jimgrim77's Avatar
    Nov 2011
    957
    Sounds good dave.
    They do look good. How does the 380 compare with 400?
    Are they easy to install, cable wise? Would you recommend auto technician install etc?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Im getting the 400 hd2 there are vids on you tube, install will be simple taken off a permanent live from the courtesy light area...the electrical draw is very low...
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    Mine is installed to the fuse board using the aux socket in the boot live feed. I have also bought a 32gb sd card and get approx 30 hours record time before overwrite in normal and park mode. I keep the 16gb card in the car in case I need to save the footage on the 32 card, I can just put the 16 in until I have uploaded it to the PC.
    The cable supplied has a plug for the cigar lighter socket. If you want it on permanently you can also get a Powerpro device that you wire in and connect the camera cable to which turns off the camera if the voltage drops below a certain level.
    My car was not used all of last week and still started ok after 6 days so the power used for the camera is low.
    Footage from mine, I have the DR380DG, played back without sound. (only the first 15 seconds are relevant)
    KL08 DXH White van idiot jumping red light - YouTube
    JSD 2.59
    Synergy-Solutions
    Jimgrim77's Avatar
    Nov 2011
    957
    Great piece of kit. Thanks.
    its on the Christmas list now.
    That white van man was a tool!
  1. A3 glovebox does anyone have one for sale?
    By rusko007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2011, 22:02
  2. are these secure does anyone have one?
    By kirsty76 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th November 2011, 09:04
  3. vag com quierys plus anyone have one near southport
    By the jammy one in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th March 2011, 22:53
  4. ABT badge - Anyone have one?
    By Az in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2009, 19:25
  5. What kind of light is this? Does anyone have one
    By sherry in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th April 2008, 18:52
