Chris NottEM Tuning
Like Tree1Likes
  • 1 Post By Squirrelofdoom
Thread: Rear Wiper motor replaced-jet not working properly
    Oct 2012
    57
    Hello,
    As above says replaced the motor at weekend wiper arm works great with no stutters!, however I am only getting a slight dribble from the washer jet!.
    This is what I have checked so far
    1/Washer bottle topped right up
    2/Washer motor working as can hear it
    3/ Washer jet nozzle cleaned and free of obstruction
    4/ Sucked the washer pipe till liquid came through
    5/ no leakage from motor
    6/ no visable leakage in footwells etc
    Could my problem be at the front of vehicle ie washer bottle motor or something?
    Any advice welcome!
    Jason
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    355
    I've seen it where the joint in the pipe behind the sub in the boot leaks and all the screenwash ends up being held in a big void below the central locking pump so it doesnt show on the boot carpet or dribble out, might be that
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    538
    the pipe has 2 joins; one behind the sub as mentioned, the other in the trunking below the airbox - try both of those. If not then you might want to take apart the motor and make sure the spindle inside hasn't snapped
    S3 chj likes this.
    Oct 2012
    57
    Hi, Have read the suggestions and it has lead me to looking in the void below the central locking, how can you gain access down there? it looks like someone has placed a plastic bag around the central locking motor which would suggest that it has happened before or they are just protecting the motor. Are the pipes coloured i have seen a yellow/pink pipes? Will have another look anyway!
    cheers
    jason
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    355
    the pipes to the central locking pump are coloured, i think mine were blue and yellow. the hose for the rear washer should just be black and corrugated, it might be wrapped in cloth tape.
    to gain access to the join behind the sub you have to remove the sub, there are a few nuts dotted around that need removed and the trim that needs removed then that's it.
    epox's Avatar
    Oct 2012
    Glasgow
    593
    hi. might sound daft, how long are you holding the wiper leaver for? mine takes quite a while to push the water through to the rear jet.
    also had to blow air through the rear wiper to fully clean the crap out.
    mark
  1. Rear Windscreen wiper stuttery/water jet not working-any ideas?
    By jnielow in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2012, 12:50
  2. Water in footwell + rear washer jet not working + aircon knackered
    By munchkincoupe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2011, 14:57
  3. rear wiper on b6 avant,, not working!
    By Leaky Lloyd in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th July 2010, 19:45
  4. Anyone replaced rear wiper motor?
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2005, 12:39
