Monster MotorsportEM Tuning
Page 1 of 2 12 LastLast
Results 1 to 40 of 69
Like Tree8Likes
Thread: S3 8L Custom Exhaust Flow
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    823
    Hi guys,
    I have on my S3 the following:
    XS/Pipewerx 3'' DP
    XS/Pipewerx 200 cell sports cat
    Milltek Resonated cat back
    Long story short, the sports cat reduces down from 3'' to between 2'' and 2.5'' iirc and sleeves into the Milltek system but for one reason or another the sleeving is incorrect and exhaust gases are blowing past, thus creating a whistle when throttle is applied.
    My plan is to modify the sports cat (cut back to the 3'' bore) and tig weld a 5ft straight stainless pipe all the way through to the rear silencer, thus removing the resonator box and most of the exhaust bends creating a 'straight through' centre section.
    My question is that if I am removing the exhaust bends, resonator and reducer within the sports cat (restriction) would i lose back pressure and ultimately lose power?
    I'm unsure as to why the sports cat reduces right down from 3'' but i presume this is so it fits the standard OEM cat back system and doesn't accomodate the Milltek.
    Can anyone shed any light on this?
    Thanks in advance.
    Shaun.
    Reesy's Avatar
    King of the Mods. Apparently.
    East Sussex
    3,600
    Visit Reesy's Instagram Channel
    Quote Originally Posted by ShaunS3 View Post
    Hi guys,
    XS/Pipewerx 3'' DP
    Thanks in advance.
    Shaun.
    Have a look in my thread at the last page or 2. I have just done the same thing and gone 3" straight through to the backbox..
    The reducer will be for fitting to a stock system.
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Cheers Reesy.
    I thought I had better ask before I proceeded as I've heard that removing bends etc can reduce power by creating a low velocity exhaust flow and/or too big of an exhaust bore.
    The Milltek catback is 2.75'' so i'm going to be sticking with the 2.75'' in the straight pipe and using a couple of the angle bends of the Milltek to reduce the number of welds....might aswell put the Milltek centre section to good use if i'm going to be chopping it up.
    Lewis583's Avatar
    Mar 2010
    833
    It's only really NA cars that can lose performance by not having some back pressure.
    With FI the least amount of restrictions (silencers/tightbends etc) downstream of the turbo the better, noise levels permitting ofc lol.
    You will be fine fella and don't forget to put some pics up after you are done
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Quote Originally Posted by Lewis583 View Post
    Just what i wanted to hear
    Oct 2011
    722
    Time for a new manifold????????????????????????
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Re: S3 8L Custom Exhaust Flow
    Quote Originally Posted by jezzy View Post
    No. I'm not chasing big power figures, just improving the poor fitment and gaining a better flow in the process.
    James TQ's Avatar
    Apr 2012
    Essex
    546
    [QUOTE=Lewis583;1741658]It's only really NA cars that can lose performance by not having some back pressure.
    silly question, what are NA cars, iv seen alot on n/a cams in S3's?
    Reesy's Avatar
    East Sussex
    3,600
    [QUOTE=James TQ;1741694]
    Naturally Aspirated.
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    [QUOTE=Reesy;1741695]
    Quote Originally Posted by James TQ View Post
    AKA - Non turbocharged / Non Supercharged
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    141
    Just going to back up Lewis on this one, as he says, the less restriction the better with turbo cars. Besides the turbos presence in the exhaust and the positive intake pressure killing the idea of using the NA tuning devices like pulse tuning, the turbine wheel will operate most effectively with the least amount of pressure on the down-pipe side, giving the biggest possible pressure drop through it.
    ShaunS3 likes this.
    1.8 20v turbo converted '88 Scirocco - ASN Build Thread
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Will I see more of a raspy note from this modification?
    My understanding is that the rasps are caused by the gases hitting the bends within the exhaust system but I've heard people saying it will be more raspy.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    You won't be able to run a straight pipe from the DP to the back box as the rear diff/haldex is in the way... bends in pipes do slow down air speed but on a 3" system at your power levels it is largely irrelevant...
    The standard system is fairly bend free up to the back box.... here is my 3" system next to the OEM system
    I changed this later as it was too loud on the poxy little back box...
    ...although I did try a full on straight through system for fun ;P
    Don't get too hung up on it... Miltek systems are 2.75" OD IIRC and 3" is plenty for 500+ hp
    <tuffty/>
    ShaunS3, s3clarke and IFFY_77 like this.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,453
    Shaun i have the same issues, milteks idea of 2.5 inch is alot different to relentless idea, or t'other way round, obv the americans are wrong. Anyway yeh i have a blow i cant get rid of no matter how tight i do the sleeve.
    Consider this, cut the decat/cat pipe where it is 2.75 inch, i.e where it reduces, and get a straight piece of 2.75 welded on, and the v-band both the downpipe and the miltek. Hey presto, 3inch-2.75inch all the way that will never ever leak or blow. V-band ftw
    ShaunS3 likes this.
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    That's my plan
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Quote Originally Posted by ;1741901
    <tuffty/>
    Cheers tuffty.
    I will be using some of the angle bends from the milltek donor centre section but when I said 'straight through' what I meant was as straight as possible with the resonator box removed also.
    The pipe I'm using is a 5ft straight pipe with an OD of 2.75'' to match the Milltek and will be welded up to the sports cat which is 3'' iirc.
    I am going to try and cut into the reducer where its at 2.75'' so I can weld my pipe to it rather than back to 3'' and have to sleeve and create a weld reducer if that makes sense?
    Sep 2012
    West midlands
    368
    I have done exactly the same as you are explaining exactly the same setup mate it sounds awesome too be honest I cut out the resonated section of miltek and replaced with straight pipe it's biggest restriction is the miltek back box in my opinion but without it it sounds too much lol chavvy as you can get!!! Miltek non resonated is good!
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,352
    Not a big fan of the Miltek myself, few months down the road after mapping i'm finding my back box is starting to die finding the wadding from insides of my back box over my boot lid.
    here is what Pipewerx said to me
    We could only do a custom build for this which we can do for £475 all in
    fitted. I think you will notice a lot of difference if you change the systemas the miltek is a chambered box as well as it being 70mm. at that power it
    needs to be straight through box's and a minimum of 76mm.
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,453
    Thats a good price from them andrew.
    Does Anyone else think their miltek gets insanely hot??
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,040
    Mines melted my bumper above the two tips lol
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Quote Originally Posted by Andrew@A.L.D View Post
    What mods are you running and what stage of map?
    May 2010
    Bedford
    2,877
    Read his sig...says it all really lol.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Quote Originally Posted by Jason.s View Post
    Can't see it on my phone :/
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    667
    Signature says this Shaun: Maybe the most powerful Audi 8L S3 on this forum?
    2067cc 20v GTX3076r Audi S3 now with 510+bhp. More to come.. 1150cc's injectors + More Boost = 570-590 bhp
    OEM ECU Mapped Launch Control & Anti-Lag/Full Throttle shifting
    3 Adjustable maps, GPS speed of 182mph so far
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    Sep 2012
    West midlands
    368
    Quote Originally Posted by s3clarke View Post
    must have a video too back this up?????? as if i had spent that much id have loads of videos as evidence didnt you video the dyno???
    Sep 2012
    West midlands
    368
    that flat shift you have is it a wotbox?i bet the gear change is harsh!
  28. #27
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    No wonder its red hot....running 500+ bhp through a box made for relatively standard spec models. Talk about pushing the limits!
    Personally if I was running over 500bhp, one of the first things I would do is have a custom exhaust system designed and built to cope with the power.
    Don't think Milltek will suffer half as bad on a stage 1-2 sub 300bhp S3....
  29. #28
    May 2010
    Bedford
    2,877
    Quote Originally Posted by darren t View Post
    Look in the video section at the top of this section
  30. #29
    Sep 2012
    West midlands
    368
    i have seen a video of his dosent look like 510bhp dyno video is hard evidence without this i couldnt belive lol i hope it is pmsl as it looks like mine lol minus the gt30 turbo lol
  31. #30
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    *Goes to watch videos on full pc screen*
  32. #31
    Sep 2012
    West midlands
    368
    im not saying it isnt but video is not the best and id have videoed the actual dyno run id like too see a launch 1 2nd and 3rd gears that would be nice!!!!
  33. #32
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    <tuffty/>
    niki style............... haha
    damn.. how old is this pic? no bench in the back ground!
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  34. #33
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    even our lupo is 3" full bore turbo back, x3 box system... 89db(A) @ 4500rpm
    bill@badger5.co.uk
  35. #34
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,453
    Didnt tuffty have high egts limiting power with his miltek, hence why he went 3 inch.
    Imagine the improvement on andrews car!
  36. #35
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    yep..
    its all about the flow - innit
    bill@badger5.co.uk
  37. #36
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    yep..
    What rear silencer is tuffty running?
  38. #37
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,453
    miltek, but his is 3 inch all the way with the box opened up to take it
  39. #38
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    I can imagine EGT's being high on big powered applications such as tuffty's and Andrew's but for my low 'sensible' power spec I don't think I need to worry about extremely high EGT's like they would need to.
  40. #39
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    egts on yours would be higher I predict... its less well flowing by some margin...
    bill@badger5.co.uk
  41. #40
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Surely not to a point where it becomes necessary to upgrade the rear silencer from a Miltek?
    Mine is a stage 1 with turbo back system and I don't plan to go for crazy power figures. The car is to be used daily with an occasional spirited drive.....surely EGT's only become an issue for me if being used for prolonged hard track use for example.
  1. custom exhaust by mij
    By jordychris in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd April 2008, 14:37
  2. custom exhaust!
    By antonio2131 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2008, 23:44
  3. Custom exhaust V's Supersprint
    By Aky in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th October 2007, 17:59
  4. Custom Exhaust Places
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2007, 19:45
  5. Custom exhausts near Surrey??
    Last Post: 16th March 2007, 15:51
