Sky InsuranceBadger5
    Dec 2011
    Bedfordshire
    142
    Cruise control issue
    My s3 has cruise fitted but has never worked I have checked the switch on the clutch pedal with a continuity tester and it makes and breaks like I guess it should I don't have any fault codes relating to it I guess there is also a switch on the brake pedal if that's ok where else should I look maybe a fuse? Thanks in advance
    beachbuggy's Avatar
    Surrey
    1,746
    You can che knthe brake and clutch with vagcom. Are you sure its enabled ? Vagcom again login on the engine module with 11463 to enable it. May the Ecu was changed at some point and its not enabled.
  1. Cruise control issues!
    By Breezey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th September 2012, 19:23
  2. retrofit cruise control coding and activation issue
    By deian3387 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2012, 18:58
  3. Cruise control fitting issue
    By Turkster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th March 2010, 22:26
  4. Cruise Control,
    By t955daytona in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2003, 20:45
  5. Retrofit Cruise Control
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 16:08
