Volks AutosAH Fabrications
    May 2010
    65
    A3 TDi cold start misfire
    Hi, lately I've had a problem with my A3 TDi running really rough when started in the morning. it sometimes idles lower aswell as lumpy and when driven it will get to 2000rpm then feel like it has a really really bad misfire (and sounds like its hitting a rev limiter) then if you floor it it shakes the car really badly then will run on full throttle. changed the MAP sensor, temp sensor, have tried unplugging the MAF and have run VCDS and it has no fault codes other than an ABS sensor that i already knew about. turbo has recently been cleaned. runs fine after it warms up slightly but runs awfully when started from cold. any one had any similar issues? or know where to start looking next?
    Lewis583's Avatar
    Mar 2010
    833
    Check the glow plugs.
    Easy way to test is a follows. (you will need a test light similar to below)
    Remove all feeds to glow plugs.
    Connect clamp end of test light to positive side of battery.
    Touch probe end of test light to one glow plug terminal at a time
    If glow plug is okay the light will illuminate, if they're knackered it won't light up. Perform test on all glow plugs
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    colicabcadam
    i thought glow plugs just warmed the cylinder up prior to starting, to do nothing other than help it start
    they do not stay on once the engine is running, so why would it be them ?
    Lewis583's Avatar
    Mar 2010
    833
    Not 100% sure on VAG diesels, but on some other marques the glow plugs stay on for a duration after the engine has started, to help maintain cylinder heat and idling.
    It's a simple enough test to do, so will rule them in/out quickly.
    Full VCDS
  1. Cold start problem - A3 2.0 TDi 170
    By matt_t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2014, 00:12
  2. 2.5 TDI Cold start issues
    By neilA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th December 2011, 22:18
  3. 2.0 tdi cold start problem
    By influxsg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st June 2011, 21:53
  4. spluttering and misfiring on cold start-up cured
    By voorhees in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2008, 10:58
  5. Cold Starting an A3 2.0 TDi 170.....
    By SMc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th January 2008, 19:37
