Badger5JMB Retrofits
Results 1 to 9 of 9
    May 2012
    Manchester
    229
    drivers door not opening in frost
    My drivers side door wont open from the outside in the frost, there is no resistance on the handle it just lifts up asif the door is still locked and the door wont budge. But if i climb through the passenger side and open it from the inside it opens as normal. And once the car has warmed up it works fine. Anyone else having this problem and know how to sort it? its getting on my nerves a bit and im considering dipping the locking mechanism in antifreeze
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    Yes it's pretty common, it's the catch mechanism freezing. Spray some lubricant on the mechanism and should be fine
    09 white black edition a3 2.0 tdi 😃
    99 silver apy s3 - revo stage 2 mapped - relentless downpipe + sports cat - cat back milltek - fmic - piper x panel filter - silicone tip - forge 007 - vmaxx coilys - andy mac stealth sub - wilwood 4pots and r32 discs - h &r spacers - bbs ch wheels or std gunmetal grey alloys
    May 2012
    Manchester
    229
    cool cheers, do i need to take the door card off or just spray the bit you can see? will wd40 or silicone lube be best?
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Don't remove the card! spray what you can see and into the lock as well! if it continues, get some graphited lube in the lock itself, then work the key a few times. it's just ice in there.
    note: a temporary solution is to heat your key for 20 secs with a lighter before trying it.
    2009 A3 SB 2.0T DSG S line
    May 2012
    Manchester
    229
    sprayed it with wd40 and the bloody frost hasnt been back since so will have to wait and see. That reminds me though some cars have heated locks when you hold the key in the unlock position for a certain amount of time, do these cars have it?
    Feb 2012
    Denmark, Copenhagen
    205
    Pretty sure they dont, Karl.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    I'd say its the rubber door seal iced up to the body.
    May 2012
    Manchester
    229
    its definitely not the rubber seal because when i climbed in the passenger side and opened the drivers door from the inside it opened asif it was a summers day!
    Just had a look in the handbook now, page 12. The heated door locks are activated by pulling the door handle breifly. The system operates at outside temperatures below 5 degrees C. The heating stays on for 50 seconds and you can re-activate it again by breifly pulling the handle again.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Quote Originally Posted by voorhees View Post
    Vaseline\Silicone spray on the door frame rubbers prevents sticking & tearing too ..but you need the doors open to apply it.
    that reminds me, my boot lid got stuck the other night! I'm off to do it before the frost returns.
  1. Rear driver side door not opening...
    By blyths24 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st May 2012, 15:59
  2. Help! Drivers Door Wont Open! 2002 A4
    By Gibonz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th January 2011, 21:59
  3. driver door not locking
    By stu_m in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th December 2010, 11:33
  4. Drivers door not opening from outside.
    By nomadx in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th January 2010, 12:09
  5. Drivers Door Not shutting Properly
    By myrichdad in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2006, 19:17
