Volks AutosMonster Motorsport
Results 1 to 7 of 7
    gez
    S3 hunter
    Sep 2009
    Middlesex
    98
    Boost pressure and airflow query
    Logged my airflow using a snapon solus pro to get a rough idea on power.
    seeing 187gs on full throttle 3rd gear. Am i right to guess it equates to 260hp?
    Also logged 2490 mbar of boost which equates to 2.4 bar boost pressure?!?!?
    Bam engine
    revo2, v3manifold, 3"downpipe and 120cell cat, ahfab fmic, B5 v3 intake, std airbox with pipercross filter and 4"cold feed
    Is it about right or is my airflow metre getting old and reading poor?
    Yohan87's Avatar
    May 2011
    404
    Not quite.
    Your MAP sensor won't read higher than 2.5BAR, plus you have to subtract atmospheric pressure from that, approximately 1000mbar. You're not making 33psi lol.
    I'd expect more power from the mods you have described.
    What fuel are you on?
    gez
    S3 hunter
    Sep 2009
    Middlesex
    98
    Only on regular unleaded as shell had run out of v-power last night. Would that make "much" difference?
    with these mods what airflow reading should i expect?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,951
    look at cf 020 for what your engine thinks of the fuel for that boost AND log lambda 031
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,079
    2490mb logged is around 1490mb of boost, so call it 1.5 bar, 22psi.
    g/s - bhp conversion is /0.8, so 187g/s implies around 234bhp.
    Typical st1 BAM would expect around 200g/s, many with your sort of spec are seeing 220g/s+.
    that's not to say that MAF figures should be taken as gospel, but it's certainly a very low reading compared to those typically seen with your level of hardware.
    gez
    S3 hunter
    Sep 2009
    Middlesex
    98
    Ok bill will log them tomorrow and see.
    car pulls very well and doubt its making 230bhp. Is it more likely that my air flow sensor is playing up?
    spose getting it on the rollers for a true reading is the best idea
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    827
    Add Vex182 on Facebook
    I had a run in mine earlier and got 231g at the MAF (288bhp!?) so m MAF will be working but no way is it running that much power. I would have thought hours would be high like mine too with your spec and this cold weather. That was 4th and WOT.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
  1. Would this cause boost pressure to decrease and bad MPG?
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2012, 12:58
  2. Stock and remap boost pressures...what should they be?
    By g10chy in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2011, 18:56
  3. Water temperature and boost pressure
    By adam8747 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2010, 18:22
  4. Agu boost pressure and problems please read.
    By ash_pearce in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2009, 11:01
  5. Drop in boost pressure and power :-(
    By HTC in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2005, 23:07
