Flemboy1990
- Joined
- Nov 21, 2012
- Messages
- 23
- Reaction score
- 0
- Points
- 1
Hey guys first post so be gentle lol, got an audi s3 02 with the BAM engine, got an oil leak, oil is running down the rear of the engine on the cam belt side, pretty sure it's rocker cover gasket, so I changed it and the cam chain tensioner gasket but its still leaking :S. the cct gasket I put I'm seems fine there's no oil around that side of the engine since I changed it, so don't know if I made a mistake, or the gasket I bought was s**t or I did t use enough gasket sealant etc, just wondering what is the best gasket sealant to use?? Is there any harm in covering the entire surface of the head where the gasket sits?? Is there also a particular order for the rocker cover bolts to be tightened back up?? With the old gasket that was on there the only place it was wet with oil was right at the back of the engine on the cambelt side, now with this new gasket in there it looks moist and wet all the way around other than the side where the cct is?? :S
any help would be much appreciated
other than that loving the s3
