JMB RetrofitsEM Tuning
    Oct 2012
    Stockport
    34
    Rumble from rear when reversing
    When reversing with people sat in the back there is a rumbling noise from the rear. Sound like something is dragging on the road.
    There is also knocking coming from the rear going over big bumps but only with people sat in the back.
    Fine without anyone sat in the back.
    Recently passed an MOT with no advisories.
    Audi A3 1.8T 2001 AUM - Custom Stage 2 Map. 3" De-cat Downpipe, 2.5" System, 100mm SMIC, CAI, BKR7E Plugs, Forge Recirc Valve. Uprated Clutch with Lightened SM Flywheel. SAI, N249 Removed, Simplified PCV with Oil Catch Can, Silicone Vac and Boost Hoses.
    Seat Altea 2.0TDi DSG 2004 BKD - Custom Stage 1 Map. Now with new Engine, Turbo, Intercooler, Piping and Radiator (due to Turbo failing and dumping bits into the engine)
    Essentials - VAG-COM. WinOLS.
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    147
    Sounds like the exhaust's hitting something under there. It shows up more in reverse because of the way the engine flexes on the mounts. Do you get a knock when you lift off sharply at high revs too? Have a look to see if it's obviously close to anything, doing it more/only with weight in the back suggests that what it's hitting is probably the rear beam.
    1.8 20v turbo converted '88 Scirocco - ASN Build Thread
    Oct 2012
    Stockport
    34
    The exhaust is loose at the joint where the back box meets the middle pipe. Looks like some has done a PPR (p**s poor repair) on it.
  1. Replies: 10
    Last Post: 25th July 2011, 20:45
  2. rumble from the rear....help
    By S4twiggy in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th February 2010, 21:10
  3. Strange noise from rear brakes.... When driving..?
    By Rafkoo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th September 2009, 13:03
  4. rumble from the rear - any answers??
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2007, 12:23
  5. grinding sound from rear when turning
    By Jay in forum Handling
    Last Post: 12th January 2007, 08:31
