Chris NottJMB Retrofits
Results 1 to 8 of 8
    Oct 2012
    Help please :( Passenger window not going the whole way up!!
    Morning all!
    I have a 01 Audi A3 and have had problems with the windows (amongst plenty of other things) since I bought the darn thing, but this morning I wound the passenger window down, in order to be able to see through it, and now it won't go the entire way back up. It gets to halfway and then winds back down again. It has done this for quite a while and normally if I hold the button up it eventually goes all the way up. However this morning it seems to think that the window it completely closed when in fact its 2-3 inches from the top. Is there anyway of getting the window up manually? I'm concerned with the bad weather on the way that leaving it open is going to damage my car even more, and it really doesn't need help in that department! I have tried lifting it manually, advice from the other half thats 200 miles away, but that doesn't seem to want to make it move and I am conscious that I may break the window if I'm too rough with it. Any advice or help on how to get the damn thing back up would be gratefully received.
    Anne
    Apr 2012
    605
    Re: Help please :( Passenger window not going the whole way up!!
    Just done mine it be the clips broken go scrap yard and get a new clIPs be fine again ..
    Stalking Kate Beckinsale
    Nov 2011
    Farnham
    52
    I had this with the one we just bought, caught it during the test drive. With precise timing after pressing the up button, careful jiggling and a bit of patience I got the window back up. had that fixed before picking the car up.
    You have got no choice other than to persuade it up while pressing the up button or get some duct tape on their stat for the drive home?
    MiniMetro <1.1 Escort <1.6 Escort <106 XSI <106 GTI <WRX <STI2 <STI5 "Fluffy" <Evo VII "Helga" <XJR
    "Brutus"- RS6- MRC stage 2- Milly non-res+ sport cats- PSS9- H&R ARBs- OZ Superturismo LM/Michy PSS- 547PS/826Nm
    RS4 - Milly non-res- TTRS Wheel- SDS- BT- Latest Gen RNS-E- F1 Asymm2
    S3 BAM- MRC stage 2- Badger5 TIP+ shield+ cone+ phenolic spacer - Milly non-res + AmD sport cat- F1 Asymm2 - 283PS/411Nm
    Audi Technical file archive - http://bit.ly/TZ2hJb
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    Just open door and put your hand on outside of window and help it up while pressing the button.... I have same problem on both my windows.....
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,250
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    I believe the best thing to do is to purchase the Audi A6 clips for it as they are re-enforced with metal and not fully plastic.
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,366
    My passenger window has dropped, I've bought the eBay kit ready to crack on with it. I just wondered has anyone done it???
    I took door panel off, then metal sheet behind removed 8 x10mm screws , undid all electric plugs for speaker , window ect but I couldnt remove the metal panel there was still something holding it. Like I said today was a practice run just to see what I'm up against for when the kit arrives but anyone who has done this before and has a tip or two let me know please.
    Sean
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
    May 2012
    RETFORD, NOTTS
    1,748
    Isnt there a way to 'relearn' the window fully up and down?
    something like hold the up button till its all the way up then push up and release, then hold it all the way down then push down and release?
    Im sure i screwed my windows up before and did this and they have worked ok since.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    chris99's Avatar
    s3 driver
    Dec 2010
    54
    Sean, check this thread Broken window? Window clips? Window regulator? or motor? Guide inside , it's pretty straight-forward.
    Did mine before seeing that, bought the full repair-kit but all I got was that broken plastic clip.
    Audi S3 8L
    OZ Superleggera | Bilstein B14 | BMC CDA | K04 | FMIC | SACHS Race Engineering | Brembo Sport GT | EBC Redstuff
    Live to drive, drive to live
  1. Please Help Passenger Windows not working!
    By gsmboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2012, 08:54
  2. HELP! please! car partly dismantled in the garage
    By mattpanton in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2011, 12:56
  3. Drivers Side Window - Not Going Down With The One Touch
    By silversurfer in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2010, 10:12
  4. A3 Passenger windows not working please help!
    By EvoFQ400 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2009, 08:15
  5. Passenger Window Keeps Going Down! Help!
    By emzino in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd July 2008, 01:52
Tags for this Thread
