Monster MotorsportChris Nott
Results 1 to 12 of 12
    Tricki's Avatar
    Getting into it
    Nov 2011
    Bergen, Norway
    114
    Exclamation Advise needed! Have to change my turbo...
    During some work on my 2002 S3 AMK, the guy at the work shop discovered play in the turbo, according to him severe play. They advised me to get a "new" refurbished turbo and they come up with a price for the turbo of £1300 + labour.
    So I'm thinking, is there any other way to come about this? Can I refurb it myself? Should I go for a turbo upgrade? Is there any good deals to be had online or somewhere in the UK for replacement turbos (I'm located in Norway)?
    Please advise and comment, I want to get it sorted asap, but not get ruined....
    S3 2002 AMK | O.CT stage 1 | K&N | Forge 008 | H&R Spacers R20/F10 | H&R Springs | N249 Deleted
    Forge Tie Arms | Forge Short Shift | Forge TIP | 18" TSW Nurburgring Gunmetal w/GY ASY2 | Mintex Discs (F)
    Next : Bilstein
    B8's + ARB's | Haldex Competition Controller
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Beachbuggy on here will sort you out... pm him..
    Tricki's Avatar
    Getting into it
    Nov 2011
    Bergen, Norway
    114
    Got a quote: £2400 total for new turbo and labour.... Must be possible to get something else than standard for that money....
    Next : Bilstein
    Yohan87's Avatar
    May 2011
    405
    Norwegian prices for you...
    As Dave said, Beachbuggy (Dan) on here should be able to help you out.
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,651
    As above, Speak to Dan (BeachBuggy). For that price you should easily be able to upgrade...
    Currently rolling in a SKODA!!!
    Tricki's Avatar
    Getting into it
    Nov 2011
    Bergen, Norway
    114
    I made a call to another dude, known for his skill with Audi turbo tuning, and he said that the K04 has floating bearings and there is some play in it from new. The bearing is self-centralising when the turbo spins up. From what I told him he thought my turbo is perfectly fine! He said that if it was worn, the impeller will scrape the housing and I would see white smoke from the exhaust. So, in his opinion it was BS what the workshop told me.... He also said the K04 is very reliable, and although my car has done 100k miles, it should be fine.
    Any opinions on this? Is he correct that there is play from new? is 100K miles nothing for the K04?
    Next : Bilstein
    beachbuggy's Avatar
    Surrey
    1,747
    True, side play isn't a big issue its the in/out play that you gotta watch, if there is any then it's on its way out sooner or later, it compounds and gets worse very quickly.. More so if running high boost spikey pikey maps that thrust the internals back and forth as you makes boost, the hammering wears the thrust bearing out very quickly.
    Tricki's Avatar
    Getting into it
    Nov 2011
    Bergen, Norway
    114
    Quote Originally Posted by beachbuggy View Post
    Ok, this is what I've got, in and out play.... So no good then.
    What options am I looking at if I go for upgrade? Apart form the turbo what do I need? Downpipe I guess, but the rods on the AMK should be ok for about 300 bhp, right? I 've already got the Forge TIP fitted, that's when the play in the turbo was discovered....
    Anything else?
    Next : Bilstein
    Tricki's Avatar
    Getting into it
    Nov 2011
    Bergen, Norway
    114
    Ok, so I got a few options, a kind offer by beachbuggy to sort me out with new internals (well, not me, but the turbo), or buy a complete unit. So if I go for a complete unit, where to get one?
    Next : Bilstein
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Turbo dynamics..etc
    But it should be a No brainer ..... take Dans offer up....
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,389
    turbo new price is FAR too high, places like backdaft are doing brand new OEM ko4's for about £500 these days.
    Tricki's Avatar
    Getting into it
    Nov 2011
    Bergen, Norway
    114
    Turbo dynamics..etc
    Well, I like to cover my options first, but so far Dan is on top of the list.
    Having said that, anyone got experience with the Frankenturbo kits?
    FrankenTurbo | F23 Hybrid K04 turbo for Audi TT225, S3 & MkIV cars
    Next : Bilstein
  1. need someone to change the clutch/flywheel for me
    By abdus in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2007, 23:13
  2. Advise needed please!
    By Luckymonkey in forum Detailing
    Last Post: 19th April 2007, 10:29
  3. Newbie!! Advise needed on alloy wheels?
    By audicoupegt in forum The Welcome Section
    Last Post: 23rd August 2006, 23:09
  4. misfiring fault, tech help needed - have vagcom fault codes
    By shufti in forum General Technical / How To
    Last Post: 16th June 2006, 22:14
  5. ADVISE NEEDED PLEASE
    By Dannycanyon in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2005, 16:45
