EM TuningVolks Autos
Thread: VAG-COM Logs
    Whoever does not try, does not learn.
    Feb 2004
    Surrey
    193
    VAG-COM Logs
    Hello,
    I was playing around with my friends vag-com, and I had generated some logs. I was just wondering whether I can get some feedback on your thoughts with the values that were generated.
    Note, that these values consist of 2nd, 3rd and 4th gears – I’ve just found, and ideally should have done this http://www.vaglinks.com/OBDII/Vag-co...d_Graphing.pdf. I’ll see if can get the cable again, and get some proper readings.
    TIME Group 2 - Field 0 TIME Group 2 - Field 1 TIME Group 2 - Field 2 TIME Group 2 - Field 3 TIME Group 4 - Field 0 TIME Group 4 - Field 3
    STAMP Engine Speed - (G28) STAMP Engine Load STAMP Injection Timing STAMP Mass Air Flow - Sensor (G70) STAMP Engine Speed - (G28) STAMP Intake Air - Temperature (G42)
    /min % ms g/s /min °C
    34.71 2680 34.71 13.5 34.71 1.7 34.71 3.97 34.41 2960 34.41 27
    35.31 2120 35.31 27.8 35.31 3.06 35.31 13.89 35 2440 35 30
    35.92 2040 35.92 65.4 35.92 6.12 35.92 29.61 35.61 2040 35.61 32
    36.52 2120 36.52 85 36.52 7.82 36.52 37.53 36.21 2080 36.21 32
    37.12 2240 37.12 94.7 37.12 8.5 37.12 42.19 36.81 2160 36.81 31
    37.71 2360 37.71 99.2 37.71 8.84 37.71 45.78 37.42 2280 37.42 30
    38.33 2520 38.33 100.8 38.33 9.18 38.33 48.11 38.03 2440 38.03 28
    38.93 2640 38.93 94.7 38.93 8.5 38.93 48 38.63 2600 38.63 27
    39.54 2760 39.54 84.2 39.54 7.48 39.54 42.25 39.23 2720 39.23 27
    40.14 2880 40.14 80.5 40.14 7.14 40.14 42.53 39.84 2840 39.84 27
    40.74 2960 40.74 78.9 40.74 7.14 40.74 45.31 40.44 2920 40.44 27
    41.35 3040 41.35 75.2 41.35 7.14 41.35 43.31 41.04 3000 41.04 27
    41.95 3120 41.95 74.4 41.95 6.8 41.95 44.56 41.65 3080 41.65 27
    42.56 3200 42.56 73.7 42.56 6.8 42.56 45.14 42.25 3160 42.25 27
    43.16 3280 43.16 68.4 43.16 6.12 43.16 41.06 42.85 3240 42.85 27
    43.76 3320 43.76 65.4 43.76 6.12 43.76 40.97 43.46 3280 43.46 27
    44.36 3360 44.36 64.7 44.36 5.78 44.36 41.22 44.06 3320 44.06 27
    44.97 3400 44.97 63.9 44.97 5.78 44.97 41.67 44.66 3360 44.66 27
    45.57 3400 45.57 52.6 45.57 4.76 45.57 26.78 45.27 3400 45.27 27
    46.17 3400 46.17 48.1 46.17 4.76 46.17 31.42 45.87 3400 45.87 27
    46.78 3400 46.78 48.1 46.78 4.42 46.78 31 46.47 3400 46.47 28
    47.38 3440 47.38 91.7 47.38 8.84 47.38 68.75 47.08 3400 47.08 28
    47.98 3640 47.98 133.1 47.98 14.28 47.98 93.81 47.68 3560 47.68 27
    48.59 3920 48.59 127.8 48.59 13.6 48.59 94.36 48.28 3800 48.28 26
    49.19 4160 49.19 114.3 49.19 12.24 49.19 86.94 48.89 4040 48.89 24
    49.79 4280 49.79 44.4 49.79 3.74 49.79 9.83 49.49 4280 49.49 23
    50.4 4200 50.4 12.8 50.4 1.36 50.4 6.89 50.1 4280 50.1 23
    51 4160 51 12.8 51 0 51 8.94 50.7 4160 50.7 25
    51.6 4200 51.6 100 51.6 10.88 51.6 96.64 51.3 4200 51.3 28
    52.21 4520 52.21 128.6 52.21 13.6 52.21 105.28 51.91 4360 51.91 27
    52.81 4800 52.81 123.3 52.81 12.92 52.81 114.22 52.51 4640 52.51 25
    53.41 5040 53.41 109.8 53.41 11.22 53.41 106.61 53.11 4960 53.11 24
    Audi S3 BAM Revo Stage 1 (265 bhp) with N249 Bypass & Forge007d.
    Audi S3 (52) 265bhp Revo Stage 1
    RIP S3dave
    May 2004
    nr Glos
    7,183
    yea. they meaningless but its your first time.. so....
    choose a safe place to do a 3rd or 4th gear full throttle run.
    vcds the following blocks and log
    002,020,115 for airflows, timing corrections, requested and actual boost
    003,020,118 for airflows, ign, timing corrections, actual boost, air temps, n75 duty cycle..
    Do logs from 2krpm to limiter
    then there will be something to comment on (for starters)
    good luck
    drive safe
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Feb 2004
    Surrey
    193
    Thanks for the information.
  1. Help understanding VAG-COm logs
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2010, 23:15
  2. Vag-com logging.
    By Y83OLK in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2009, 21:26
  3. VAG-Com: Logs & Related
    By AJames in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th August 2009, 15:38
  4. help with vag-com log
    By vinceemmery in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th August 2009, 17:45
  5. How do I upload vag com logs?
    By Jay in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2009, 14:06
