Hello,
I was playing around with my friends vag-com, and I had generated some logs. I was just wondering whether I can get some feedback on your thoughts with the values that were generated.
Note, that these values consist of 2nd, 3rd and 4th gears â Iâve just found, and ideally should have done this http://www.vaglinks.com/OBDII/Vag-com_Data_Logging_And_Graphing.pdf. Iâll see if can get the cable again, and get some proper readings.
Audi S3 BAM Revo Stage 1 (265 bhp) with N249 Bypass & Forge007d.
TIME | Group 2 - Field 0 | TIME | Group 2 - Field 1 | TIME | Group 2 - Field 2 | TIME | Group 2 - Field 3 | TIME | Group 4 - Field 0 | TIME | Group 4 - Field 3 |
STAMP | Engine Speed - (G28) | STAMP | Engine Load | STAMP | Injection Timing | STAMP | Mass Air Flow - Sensor (G70) | STAMP | Engine Speed - (G28) | STAMP | Intake Air - Temperature (G42) |
/min | % | ms | g/s | /min | °C | ||||||
34.71 | 2680 | 34.71 | 13.5 | 34.71 | 1.7 | 34.71 | 3.97 | 34.41 | 2960 | 34.41 | 27 |
35.31 | 2120 | 35.31 | 27.8 | 35.31 | 3.06 | 35.31 | 13.89 | 35 | 2440 | 35 | 30 |
35.92 | 2040 | 35.92 | 65.4 | 35.92 | 6.12 | 35.92 | 29.61 | 35.61 | 2040 | 35.61 | 32 |
36.52 | 2120 | 36.52 | 85 | 36.52 | 7.82 | 36.52 | 37.53 | 36.21 | 2080 | 36.21 | 32 |
37.12 | 2240 | 37.12 | 94.7 | 37.12 | 8.5 | 37.12 | 42.19 | 36.81 | 2160 | 36.81 | 31 |
37.71 | 2360 | 37.71 | 99.2 | 37.71 | 8.84 | 37.71 | 45.78 | 37.42 | 2280 | 37.42 | 30 |
38.33 | 2520 | 38.33 | 100.8 | 38.33 | 9.18 | 38.33 | 48.11 | 38.03 | 2440 | 38.03 | 28 |
38.93 | 2640 | 38.93 | 94.7 | 38.93 | 8.5 | 38.93 | 48 | 38.63 | 2600 | 38.63 | 27 |
39.54 | 2760 | 39.54 | 84.2 | 39.54 | 7.48 | 39.54 | 42.25 | 39.23 | 2720 | 39.23 | 27 |
40.14 | 2880 | 40.14 | 80.5 | 40.14 | 7.14 | 40.14 | 42.53 | 39.84 | 2840 | 39.84 | 27 |
40.74 | 2960 | 40.74 | 78.9 | 40.74 | 7.14 | 40.74 | 45.31 | 40.44 | 2920 | 40.44 | 27 |
41.35 | 3040 | 41.35 | 75.2 | 41.35 | 7.14 | 41.35 | 43.31 | 41.04 | 3000 | 41.04 | 27 |
41.95 | 3120 | 41.95 | 74.4 | 41.95 | 6.8 | 41.95 | 44.56 | 41.65 | 3080 | 41.65 | 27 |
42.56 | 3200 | 42.56 | 73.7 | 42.56 | 6.8 | 42.56 | 45.14 | 42.25 | 3160 | 42.25 | 27 |
43.16 | 3280 | 43.16 | 68.4 | 43.16 | 6.12 | 43.16 | 41.06 | 42.85 | 3240 | 42.85 | 27 |
43.76 | 3320 | 43.76 | 65.4 | 43.76 | 6.12 | 43.76 | 40.97 | 43.46 | 3280 | 43.46 | 27 |
44.36 | 3360 | 44.36 | 64.7 | 44.36 | 5.78 | 44.36 | 41.22 | 44.06 | 3320 | 44.06 | 27 |
44.97 | 3400 | 44.97 | 63.9 | 44.97 | 5.78 | 44.97 | 41.67 | 44.66 | 3360 | 44.66 | 27 |
45.57 | 3400 | 45.57 | 52.6 | 45.57 | 4.76 | 45.57 | 26.78 | 45.27 | 3400 | 45.27 | 27 |
46.17 | 3400 | 46.17 | 48.1 | 46.17 | 4.76 | 46.17 | 31.42 | 45.87 | 3400 | 45.87 | 27 |
46.78 | 3400 | 46.78 | 48.1 | 46.78 | 4.42 | 46.78 | 31 | 46.47 | 3400 | 46.47 | 28 |
47.38 | 3440 | 47.38 | 91.7 | 47.38 | 8.84 | 47.38 | 68.75 | 47.08 | 3400 | 47.08 | 28 |
47.98 | 3640 | 47.98 | 133.1 | 47.98 | 14.28 | 47.98 | 93.81 | 47.68 | 3560 | 47.68 | 27 |
48.59 | 3920 | 48.59 | 127.8 | 48.59 | 13.6 | 48.59 | 94.36 | 48.28 | 3800 | 48.28 | 26 |
49.19 | 4160 | 49.19 | 114.3 | 49.19 | 12.24 | 49.19 | 86.94 | 48.89 | 4040 | 48.89 | 24 |
49.79 | 4280 | 49.79 | 44.4 | 49.79 | 3.74 | 49.79 | 9.83 | 49.49 | 4280 | 49.49 | 23 |
50.4 | 4200 | 50.4 | 12.8 | 50.4 | 1.36 | 50.4 | 6.89 | 50.1 | 4280 | 50.1 | 23 |
51 | 4160 | 51 | 12.8 | 51 | 0 | 51 | 8.94 | 50.7 | 4160 | 50.7 | 25 |
51.6 | 4200 | 51.6 | 100 | 51.6 | 10.88 | 51.6 | 96.64 | 51.3 | 4200 | 51.3 | 28 |
52.21 | 4520 | 52.21 | 128.6 | 52.21 | 13.6 | 52.21 | 105.28 | 51.91 | 4360 | 51.91 | 27 |
52.81 | 4800 | 52.81 | 123.3 | 52.81 | 12.92 | 52.81 | 114.22 | 52.51 | 4640 | 52.51 | 25 |
53.41 | 5040 | 53.41 | 109.8 | 53.41 | 11.22 | 53.41 | 106.61 | 53.11 | 4960 | 53.11 | 24 |
