Chris NottVolks Autos
Results 1 to 7 of 7
    Jun 2007
    624
    Removing lower dash
    My OBD port fell behind the dash when I attempted to connect it up - I must have pushed it too hard. Would anyone have instructions from something like Bentley manual on how to remove this lower dash so I can get access to to ODB port and put it back in place? Thanks.
    Feb 2011
    Leeds
    176
    Audi A3/S3 Workshop Manuals
    Theres a pdf manual for the interior, the instructions are definitely in there as I had the same problem
    A3 TDi 196 Bhp 340 ft-lb
    The Build Thread
    Darkside Map, PD150 turbo, Allard FMIC, SFS Outlet pipe, Polybushed, Forge Short Shift , LCR Brembos, 17 TT Comps, AP Coilovers, S3 Recaros
    AJC
    AJC's Avatar
    Surrey
    173
    Try this: Replacing Broken Clutch Pedal - How to Guide (with pics)
    Plenty of pics which should help.
    Jun 2007
    624
    Quote Originally Posted by niallh View Post
    Cheers for the replies guys.
    @naillh what did you remove to get access to your OBD port when it fell behind?
    Feb 2011
    Leeds
    176
    Quote Originally Posted by metricspaces View Post
    Im presuming you have a facelift car as the OBD port moved. On my facelift I only had to remove the panel underneath the steering wheel. Held on with T25 torx screws, of which some are hidden behind the panel on the end of the dash. Once removed the OBD port just clips back in
    The Build Thread
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,382
    take the fuse box cover off, there are torx screws in the side, remove these adjacent to the lower dash panel.
    There is a screw in the top of the right hand cubby hole, then two bottom left.
    pull your steering wheel out and down, and carefully prise off the cover that goes over the top of the column below the clocks. Then put your fingers over the top of the lower dash panel and pull backwards, if it's not been off before it'll be fairly tight, but there are just push fit clips at the top.
    Mine's been off hundreds of times now, takes about 5 minutes to remove, and 5-10 minutes to refit as it's fiddly getting it into teh white plastic guides at the bottom
    Jun 2007
    624
    Thanks guys. Mine is the pre-facelift. So the port is in the centre console down the bottom - inline with the gear stick. Guessing both your instructions are for a facelift version by the side of them?
    It's hard to tell which way on mine is easiest to get at the port.
  1. how to remove lower dash panels in 2009 A3 ?
    By RST in forum In-Car Entertainment
    Last Post: 28th January 2012, 14:00
  2. Removing lower dash triangles
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th April 2011, 18:36
  3. lower dash removal help
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th November 2006, 23:03
  4. removing lower part of front bumper?
    By skanky in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2006, 10:08
  5. Removing Lower Valances
    By james0808 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th June 2006, 10:22
