AH FabricationsVolks Autos
Results 1 to 17 of 17
    Jul 2012
    East Grinstead/ forest row
    99
    Audi S3 No boost, Turbo not kicking in?, help please, A3 S3, Audi
    i have an audi s3 8L Amk 51reg
    last week i was driving my car and sudenly had no boost, had it all apart and found that the induction pipe was split, i bought a badger5 tip replacement and no luck.
    it is almost as if my car is in limp mode but has only shut off the turbo and not limiting my speed, and without any engine lights on.
    i had a look round all the pipes and made sure everything was tight, then unplugged the battery to reset the car, and it seemed to sort my car, but two minutes later it stopped again.
    Symtoms: my car feels like a naturally asperated car, can only her the turbo a tiny bit, and almost no pressure escaping from the after market dv. (i have checked to see if it is jammed, and its not)
    Things ive done/checked:
    I have scanned the car and no errors come up, and no engine lights. the car has been remaped, but im not sure what remap as it was already done before i bought it.
    I have unplugged the N75 and made no differance.
    I have unplugged the MAP sensor, ran horrible, but no extra power.
    I have unplugged the MAF sensor, made a little differance in extra power, but no where near what it was.
    I have checked the turbo, the turbine seems fine no play at all, and not seized, no cracks on the turbo that i can see.
    when i unplugged the MAF the engine light came on as userall so i dont think it could be the ECU.
    Hunches:
    The N249 wires have recently been cut as this is got caught up, the N249 is not being used, i am going to get a 330ohm 10watt resistor and connect it up, and see if that sorts it.
    also could the larger induction hose be messing with my remap?
    could it be my engine mounts?
    Does anyone have any ideas? it would be much appreicated.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,176
    Have you bad the bumper off and checked all the lower boost pipes? So does the car drive but just not pull? Is the speed limited?
    Jul 2012
    99
    i havent had the bumper off but i have had a look under and checked for splits and tightened up the intercooler hoses, the only pipe i couldnt get to was the driver side top part of the intercooler, and no my speed is not limeted, i also can not hear a boost leak.
    also the car has tourqe up to 2500 rpm then rises up all the way like a non turbod car.
    Jul 2012
    99
    im begining to think its a boost leak because it holds enough presssure to spool the turbo untill 2500rpm, and then looses its pressure. but i cant see any cracked, split or out of place, any ideas?
    Wind Deflector Trend-setter
    Nov 2011
    Horsham
    386
    Park the car up, and put on the handbrake. Get the clutch to the biting point in 1st gear and slowly apply to the accelerator. At around 3500-4000RPM you'll hear a woosh if there's a boost leak, and get someone else to listen to where it's coming from.
    2000 Plate Audi S3 1.8T Santorin Blue - 275BHP on Custom Parsons Performance remap, Forge 007p DV, Red DogBush, Milltek non-res, Lowered 35mm Apex springs, Badger5 TIP/cone filter/heat shield, Powerflex'd, Large FMIC, Relentless Downpipe, Parsons Decat and lots of love.
    On gearbox number 4.
    Further modification to come..
    Jul 2012
    99
    thanks for that, just did it and no 'woosh' but no sound of the dump valve at all.. hmm thanks anyway mate
    Jul 2012
    99
    one more thing, when i put my foot down my traction controll light pops up as if its loosing traction, but i have almost no power and cirtainly dont have enough power to spin a 4wd, could it be my 4wd system stopping my turbo from boosting? thank you all.
    Feb 2012
    739
    my s3 has very over sensative tc and will kick in at very annoying times when not needed. think they must just be like that. it doesnt need 4 wheels spinning either if i hit a bumpy road where one will spi s it kicks in. daz
    Jul 2012
    99
    Quote Originally Posted by daz-20vt View Post
    are you sure your 4wd system is working?, and do you have decent tyres? mine never used to come up with TC
    Jul 2012
    99
    any ideas welcome, im still stuck
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,468
    You need the car scanned and logged with vcds.
    In no way should the n249 valve be electronically disconnected. Plugged in, yes. Bypassed vaccum pipes, yes. This valve is part of the esp system.
    Also check the orientation of the n75 valve is right. You may have fitted it wrong when fitting the b5 tip. In one orientation the car will over boost. In another it will run on actuator only, about 5 psi if the actuator is healthy.
    But, the car needs scanning
    Jul 2012
    99
    Put the resistor on the N249 wires and still no luck, I may need to clear any faults on my ecu, but still no luck, anyone got any ideas? And also can you explain the order/ set up of the N75 (which pipe goes where) just to triple check cheers
    Jul 2012
    99
    turned out to be the breather pipe under the inlet manifold, it was poping open under load. also a fuse had blown, all sorted now cheers.
    BENJAMIN's Avatar
    Mar 2011
    460
    Was this the one I fixed just before Christmas? If so, it's a real nice example.
    Jul 2012
    99
    it was mate cheers, im still changing parts slowly but surly, cheers for that!, im still trying to source an N249 for you.
    BENJAMIN's Avatar
    Mar 2011
    460
    Glad to hear it. What's next for it?
    No stress on the n249, just whenever you find one.
    Jul 2012
    99
    I've replaced the boost pipe that sits ontop of the turbo to a silicone one, I have replaced the crank breather pipe, I need to replace the PCV as mine has failed, bought a new silicone charge pipe, (to replace the red one you saw).
    i am putting/ doing the following:
    a milltek cat back non res,
    a forge slit r DV,
    cone filter and cold air feed,
    wheel spacers,
    replace some worn bushes,
    Change discs and pads,
    possibly get the clutch done.
  1. Audi S3 No boost, Turbo not kicking in?, help please, A3 S3, Audi
    By doughty29 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th December 2012, 12:48
  2. Audi A4 1.9 tdi turbo not "kicking in"
    By jones1066 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2012, 23:55
  3. Audi a3 1.8T turbo issues bit of help please.
    By PowellyEG in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2011, 19:45
  4. Engine light on and turbo not kicking in
    By magicdaps10 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th May 2009, 20:23
  5. Turbo not kicking in!
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2003, 11:22
Tags for this Thread
