EM TuningSky Insurance
    Sep 2011
    doncaster
    98
    turbo boost drop. help!
    car been on rollers today and after 5k the car dies and boost gos to .3bar, only fault code i have is n249 mechanical malfunction but i have the n249 bypassed. with the n75 connected the boost drops after 5k and with it disconnected it boosts more. car has stock map on, relentless mani, 3" all way thru with decat , green cotton panel, cai, large port head with transition, n249 bypass, oil catch can turbosmart recirc valve. any ideas? am struggling lol
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Sounds like a leak to me if the bypass is all plumed up properly. Best check all the pcv pipes around the inlet manifold and to the bypass.
    Sep 2011
    doncaster
    98
    have checked all, had it pressure tested today and no leaks. hoses around manifold are fine too, uprated them with silicone ones
    also got post cat lambda fault code but i have a decat, would this cause issues?
  1. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  2. Turbo boost pressure?
    By speedyp in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2009, 21:54
  3. Turbo Boost Gauge
    By K212 in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd November 2004, 02:12
  4. turbo boost?
    By edwin98 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2003, 14:06
  5. Max Turbo Boost Revo settings
    By MushroomMan in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2003, 14:54
