Chris NottAH Fabrications
    Oct 2012
    57
    Rear brake light spoiler-bulb needs changing
    Hello All,
    I have noticed that when I brake the rear brake light spoiler comes on but it seems a bulb has gone in the middle so I am getting 2 seperate lines of LED's and not one continous line of LED's.
    Can you change a bulb or do you have to changed the whole LED bar? (I read somewhere that you have to change the whole LED bar).
    Any pointers would be welcomed.
    Jason
    Pushing the limits..
    Jan 2011
    Australia
    1,314
    Add Sevv on Facebook
    you have to change the whole bar i think its 20-30 pounds from the dealer IIRC as i changed mine recently mate.. its literally two screws and a plug
    Feb 2011
    Leeds
    176
    Ive just changed the bulbs in mine, you need to remove the interior trim panel around the top of the rear windscreen. There you will find the light bar held in with 1 screw. Make sure you know which bulbs to replace before unclipping it from its harness, unclip the power harness and the red plastic cover comes off to reveal a line of bulbs. Im positive you can buy replacement bulbs from halfords, they are about £4 for two from memory.
    A3 TDi 196 Bhp 340 ft-lb
    The Build Thread
    Darkside Map, PD150 turbo, Allard FMIC, SFS Outlet pipe, Polybushed, Forge Short Shift , LCR Brembos, 17 TT Comps, AP Coilovers, S3 Recaros
    Feb 2006
    Lincolnshire
    718
    The light bar on my S3 is bulbs also. To be honest, buying them from Halfords is a very expensive way of doing it, so order a set from eBay or somewhere.
    If its anything like mine, when you replace one, a couple of the others will go off! I found my bulbs weren't actually blown at all, but the resistance in some of them must have been high and they were all over the place. I cleaned all the bars contacts, and then replaced all 10 bulbs.
    They're capless 284 bulbs from memory.
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
  1. Replies: 4
    Last Post: 5th November 2010, 18:15
  2. Which rear brake light bulb to get???
    By skyline-sl in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th November 2009, 20:51
  3. Rear brake light bulb removal! - How to?
    By FrankG in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th August 2007, 09:11
  4. B7 Avant rear brake light bulb
    By landylout in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th July 2007, 08:54
  5. Changing rear brake light
    By hardeep1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th December 2006, 10:47
