Results 1 to 15 of 15
    Oct 2012
    South Africa
    268
    Hydraulic lifters
    Hi guys,
    Is there any way to inspect hydraulic lifters?
    I think I might have a sticky one and don't want to replace them all.
    Its on a AMK motor with 100 000km.
    Lewis583's Avatar
    Mar 2010
    870
    Hydraulic lifters
    It is possible to dismantle them. It involves a couple pieces of wood and good firm hit. There are guides on the net, have a google bud.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Oct 2012
    South Africa
    268
    THank you, I found it, was looking like my arse
    HOW TO REBUILD AND CLEAN HYDRAULIC LIFTERS VAG 1.8T
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    what symptoms have you got?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Oct 2012
    South Africa
    268
    Quote Originally Posted by Alex C View Post
    When I start the car I got the chain rattle noise from the head, so after some diagnoses I replaced the cam chain tensioner, The noise is still there.
    I have also replaced the cam position sensor and did a sump service last night, noise is still there, between 1400rpm and 2000rpm when blipping the throttle.
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    ah, yeah i was going to suggest the cam chain tensioner. I had this a couple of weeks ago and suspected tappets at first but turned out to be the cam chain tensioner. Although a single tappet would have been far cheaper
    Alex S3 AMK
    Oct 2012
    South Africa
    268
    Agreed.
    I am stumped at the moment, was hoping to find sludge or a blocked oil pick up, but alas none of that, motor is very healthy looking for 100 000km
    Oil pan inside
    oil pickup
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    i think there is an official method of checking the tappets without having to take them all out - think i saw it on elsawin when i was having issues with mine. I'll see if i can find it when i get back from work if it'll be any help
    Alex S3 AMK
    Oct 2012
    South Africa
    268
    That will be greatly appreciated.
    Thank you Alex.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    100.000km isnt alot of miles.
    what can you do to tappets in taking them apart? theyre a very simple part arent they?
    nanananananananan BATMAN
    May 2012
    JHB, South Africa
    1,077
    Add MIGGZ on Facebook
    Hydraulic lifters
    No its not its 60k miles, mine does the same every now and again I hate it, but mine is very soft you only hear it if you 30cm away from the motor
    My rides thread : http://www.audi-sport.net/vb/a3-s3-f...t-journey.html
    Quote Originally Posted by Paradox1 View Post
    Healthy??? no,no,noooo
    Mine is healthy
    yours is on steriods!!!
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    Here's what I found from Elsawin
    Quote Originally Posted by Elsawin
    If the hydraulic tappets are still noisy, locate defective tappet as follows:
    – Remove cylinder head cover
    – Turn crankshaft until cams of the bucket tappet to be checked are at the top (push vehicle in direction of travel with fourth gear engaged and ignition switched off).
    – Push bucket tappet down with a wooden or plastic wedge to determine play between cam and bucket tappet.
    If it is possible to insert a feeler gauge of 0.20 mm between camshaft and bucket tappet:
    – Renew bucket tappet.
    Alex S3 AMK
    phil miller's Avatar
    Sep 2012
    Devon
    843
    Ive seen them taken apart and cleaned, but tbh the best way is to reset them, take them out wind the tappet back in a vice, tighten up back off until the tappet is spongey refit, start engine and they will rest them selfs
    Sep 2012
    West midlands
    368
    did you change the chain itself as this could be causing the rattle?
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    Quote Originally Posted by darren t View Post
    me? mines fixed - as i said turned out to be the cam chain tensioner. The fine piece of gauze that filters the oil before entering the tensioner broke and ended up entering the oil passageways and blocking the mechanism. Replaced the tensioner and it sounds fine now. Didn't replace the chain
    Alex S3 AMK
  1. 1.8t - S3 - cleaning hydraulic lifters
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2011, 15:01
  2. HOW TO REBUILD AND CLEAN HYDRAULIC LIFTERS VAG 1.8T
    Last Post: 27th April 2011, 20:34
  3. Anyone replaced hydraulic lifters?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2006, 19:59
  4. Hydraulic clutch problem.
    By imported_daryl in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2005, 04:34
  5. hydraulic fluid smell
    By imported_TurboMan in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th August 2004, 15:28
