Monster MotorsportEM Tuning
Results 1 to 30 of 30
Like Tree2Likes
  • 1 Post By 16Klappe
Thread: helpppp!!!!! Jetex filters or Bmc cone, bmc induction
    valyboi's Avatar
    Oct 2012
    Mountain Ash, RCT, South Wales, UK
    119
    Add valyboi on Google+ Visit valyboi's Instagram Channel
    If a jobs not bodged,it's not done right.
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,904
    Visit 16Klappe's Instagram Channel
    Buy the cheapest, none of them will make any difference.
    They'll probably make the car slower in fact.
    I quite often say I'm going to do things.
    Then never do them.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    825
    Add Vex182 on Facebook
    I would set Jetex and make sure it gets as much cold air as possible or stick with a standard airbox filter.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Stalking Kate Beckinsale
    Nov 2011
    Farnham
    52
    I have a BMC CDA kit that I bought for a laugh for my old XJR but realised as soon as I fit it (did less than 5 miles on it) that I wouldn't be able to feed in as much cold air as I wanted to it due to the engine bay being full of engine.... It should have 90% or so of the parts that you will need and I don't want much for it, was going to sell it for £100 + delivery.
    MiniMetro <1.1 Escort <1.6 Escort <106 XSI <106 GTI <WRX <STI2 <STI5 "Fluffy" <Evo VII "Helga" <XJR
    "Brutus"- RS6- MRC stage 2- Milly non-res+ sport cats- PSS9- H&R ARBs- OZ Superturismo LM/Michy PSS- 547PS/826Nm
    RS4 - Milly non-res- TTRS Wheel- SDS- BT- Latest Gen RNS-E- F1 Asymm2
    S3 BAM- MRC stage 2- Badger5 TIP+ shield+ cone+ phenolic spacer - Milly non-res + AmD sport cat- F1 Asymm2 - 283PS/411Nm
    Audi Technical file archive - http://bit.ly/TZ2hJb
    valyboi's Avatar
    Oct 2012
    119
    I'm new too audis tbh so what iv heared if I get some sort of cone filter I need a cold air feed too or Il loose power by sounds on it, also is it true if I get a panel filter upgrade will it mess the MAF up
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,904
    In the nicest possible way mate...
    It's a 1.6, don't bother.
    Then never do them.
    valyboi's Avatar
    Oct 2012
    119
    I appreciate what you mean but reallry I just want the noise & not too loose power
    Vex182's Avatar
    Apr 2012
    Hinckley
    825
    Make sure it gets cold air and then you should get the noise your after and still avoid to much heat soak.
    valyboi's Avatar
    Oct 2012
    119
    Thank you very much if I would get some sort silicon pipe to fit to my MAF then cone at the end this should help as it be closer to the wing and fit nice 3" pipe cold feed from the grill or fog should this be ok close to the original feed
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,904
    Quote Originally Posted by valyboi View Post
    You can route a cold air feed between the battery box and the wing, personally I would try to buy one of the CAI's for a 1.8t and try and butcher it to fit.
    The MAF is in the same place so it should be easy to modify.
    Popping out a fog light for a cold air feed is the most disgusting thing imaginable. Please don't do it.
    Then never do them.
    valyboi's Avatar
    Oct 2012
    119
    Thank you very much for the info and that looks a clean engine bay there 16klappe so basically if I find a cone I like all I got to do is use some sort of cia for a 1.8t any chance you any links for these
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,904
    That isn't my engine bay.
    Ebay, they are £30.
    Then never do them.
    valyboi's Avatar
    Oct 2012
    119
    YeH Il route it behind the bottom grill I think, I can't seam to find one on eBay
    valyboi's Avatar
    Oct 2012
    119
    its okay iv found one now, but I don't understand how I'd put the filter and wear or do you me do it same as the pic just put filter half way cut the pipe where it normaly goes
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,904
    The filter goes on the end of the pipe, down in the front bumper.
    valyboi likes this.
    Then never do them.
    valyboi's Avatar
    Oct 2012
    119
    I suppose it will look netters under the hood, but the filter will get stinking all the time
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,904
    I'm not sure what that means.
    Then never do them.
    valyboi's Avatar
    Oct 2012
    119
    If the filter will be by the bumper wouldnt it get a lot dirty than normal, I can't seam to find that cold air intake like that at that all ones I find are all one peace
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,904
    Correct, it would get dirty.
    And yes, they are all one piece that I have seen. That is the first one I have seen with a split in it.
    Then never do them.
    valyboi's Avatar
    Oct 2012
    119
    I will have to look for close up pics of this to see where the filter goes exact, I think look of this on a 1.6 would make you look twice atleast, have to clean it every week lol, I do like the look whos car is this do you know
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,904
    Not a clue. That engine bay looks pants to me, it's just a standard car with a £30 CAI.
    I can tell you exactly where the filter goes, down behind the front bumper between the wheel arch trim and the bumper. It sits behind the horns. I should know I ran one for years.
    It will be exactly the same behind your bumper as any other A3.
    The pipe for the kit looks like this -
    And the tabs mount on the original airbox mounts, the tabs are the same between a 1.6 and an A3 so I'm sure all you will need to do it make correct adapters for the MAF sensor.
    valyboi likes this.
    Then never do them.
    valyboi's Avatar
    Oct 2012
    119
    Thank you very much I deffo have to do this now, just find the correct pipe ect, did you find it was better than using Normal filter with cold feed pipe
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,904
    A normal filter with no cold air feed is the setup I have, and it is much better than one of these CAI kits in terms of longevity and filtration purposes.
    No need for a cold air intake on my car, it's a 240bhp 1.8t and the IAT's are 24* peak and 9* minimum due to the intercooler.
    Then never do them.
    valyboi's Avatar
    Oct 2012
    119
    okay thank you for that thats much more help so would i do the cai option or just get a nice cone with the cold air feed on my 1.6 i am liking the cai thing tho its diffrent for a 1,6
    Jun 2004
    Surrey, UK.
    268
    OT -Jardo, where did you get the info display from?
    cheers
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,904
    Quote Originally Posted by firestorm View Post
    cheers
    It is an app called Torque, only available for Android.
    It allows you to take readings from all of the vehicles sensors in the same way VAGCOM does, you can display them in a dashboard like this and it will do logs, clear fault codes, record videos with the information overlayed and all sorts of things.
    The boost seems innacurate but that is due to my own setup, however the other values are pulled straight from the ECU.
    Then never do them.
  28. #27
    Jun 2004
    Surrey, UK.
    268
    Thanks Jardo- I presume it'll need a cable or a wireless obd2 widget?
    Like a liquid gauge?
  29. #28
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,904
    Pretty much liquid for your phone yeah.
    It only works on facelift/ME7 cars though.
    Then never do them.
  30. #29
    Jun 2004
    Surrey, UK.
    268
    Great, should work with my bam engine then
  31. #30
    valyboi's Avatar
    Oct 2012
    119
    Finaly got my self a jetex filter all need now is filter adaptor
  1. attaching jetex filter to maf?
    By m8arx in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th January 2011, 22:08
  2. How to secure the Jetex filter?
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th December 2010, 19:51
  3. Fitted My New Jetex Filter... what do people think of theirs?
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2010, 11:14
  4. MAF readings after Jetex filter.
    By subby in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th November 2009, 18:17
  5. bmc or pipercross induction kit
    By ALP A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2009, 15:27
