EM TuningChris Nott
    Mar 2012
    49
    Annoying misfire on the Audi :(
    Right this is what has happened so far. To begin with the misfire started when pulling onto the motorway, it was constant and when I pulled over I unplugged coil pack 1 and re-fitted and it stopped. Got 2 miles down the road and it started again, cycled ignition and it stopped. The next few days the misfire was very intermittent, but was on idle and through the whole rev range, only running on 3. My first plan of action was swapping coil packs, so I did this with num 1 & 2 and the misfire persisted on num 1. At this point I changed the plugs, and the car was sweet for about 20miles, but low and behold it come back, but now it is only when it's hot and under WOT. I cleaned the plugs and it was ok for about 10 miles and the problem has come back, same symptoms. Agu engine code. I have also tried a power output stage module and a friends MAF with no change. I have put in bkr6ek on a revo map, do u guys think it could be the fact that I am running too hot a plug?? Before it was running bkr6e's with a tighter gap and its been fine. I am really stumped, and now don't know which cylinder is now dropping as its only under WOT.
    Sorry for the assay but any input would be great on this, I'm at the end of my teather with the bloody thing lol.
    adam
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Ignition control module, by the air flter perhaps?
    Mar 2012
    49
    Yea tried that buddy, power output stage module/ignition control module
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Scan the car. Check the leads too.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    Jul 2008
    55
    Check the pipes under the inlet Mani for leaks. My AUM did the same as yours and the smaller of the 2 pipes was perished.
  1. How do you Take the circuit board off the Audi Key
    By powersurge in forum General Chat
    Last Post: 10th August 2012, 12:09
  2. Finally, the Audi S6 Plus is now introduced
    By Maxxis in forum The Welcome Section
    Last Post: 1st January 2004, 22:40
  3. For the love of the Audi TT........
    By QuaTTroLiNa in forum TT/TT-S/TT-RS Forum
    Last Post: 22nd November 2003, 04:42
  4. if you know something about the audi 90 quattro
    By brokensaab in forum Classic Audi Forum
    Last Post: 8th October 2003, 16:33
  5. Vag-Com Tunning for the Audi TDI
    By Pookie in forum Tuning
    Last Post: 29th July 2003, 21:13
