hate my first post to be a technical one but hey all!
basically my 20v wont start! put simply lol!
have replaced crank sensor as i was lead to belive all my symptoms lead to this car cutting out not starting etc, then it just got worse and worse untill it didnt start at all!
scanned with a Vag com and throttle position malfunction code was thrown, have no replaced the throttle body and ADP.OK is confirmed on vag com....all good no codes thrown at all now!
BUT car still wont fire up, battery fully charged engine cranks over but doesnt fire up,
did an ouput test to hear if the fuel pump primed and sure enough it does! so any input on this issue would be very much appreciated before i send the car off to a local specialist
PLEASE IGNORE ALL ALARM FAULTS AND LOW SIGNAL IVE RECTIFIED THESE:
Friday,30,November,2012,16:58:05:36856 VCDS Version: Release 11.11.4 (x64) Data version: 20120807 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8L - Audi A3/S3 Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76 Mileage: 221710km/137764miles ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No: 06A 906 018 C Component: 1,8l R4/5V MOTR HS V04 Coding: 04000 Shop #: WSC 00000 VCID: 224B51F7AE400908171 1 Fault Found: 01165 - Throttle Body Control Module (J338) 11-00 - Control Limit Not Reached Readiness: 0010 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl Part No: 1J0 907 379 A Component: ABS/EDS ITTAE 20 GI V00 Coding: 03604 Shop #: WSC 06435 VCID: 2F6DA8C3ED92B46088F No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl Part No: 8L0 820 043 B Component: A3 KLIMAVOLLAUTOMAT_D72 Coding: 03141 Shop #: WSC 06313 VCID: 275D40E3C562EC2040F 1 Fault Found: 01273 - Fresh Air Blower (V2) 17-10 - Control Difference - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8L0-919-xxx-17.lbl Part No: 8L0 919 910 A Component: AB-KOMBIINSTR. VDO D07 Coding: 00442 Shop #: WSC 00000 VCID: 326BA1B7FEA09988E71 Subsystem 1 - Part No: IMMO Component: IDENTNR: AUZ7Z0T0021637 IMMO-IDENTNR: AUZ7Z0T0021637 1 Fault Found: 01176 - Key 07-00 - Signal too Low ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8LO 862 257 Component: ZV-Pumpe, DWA, Funk Coding: 10056 Shop #: WSC 06317 VCID: 11290E3B5BE68290BEB 8 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01373 - Alarm triggered by Radio Ground Contact 35-00 - - ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-173.lbl Part No: 8L0 951 173 Component: Innenraumueberw. D01 Coding: 00001 Shop #: WSC 00000 VCID: EED3F5C7AA187D68439 No fault code found. End ---------------------------------------------------------------------
