Sky InsuranceVolks Autos
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 91
Like Tree4Likes
Thread: S3 8L Double DIN conversion
  1. #41
    Wind Deflector Trend-setter
    Nov 2011
    Horsham
    389
    I think your swap is a little different, as it appears you already had a double-DIN console in place, and have just bought a fascia adaptor to fit an aftermarket head unit.
    Does look nice though.
    2000 Plate Audi S3 1.8T Santorin Blue - 261.0BHP - 255.1LB/FT on Custom Parsons Performance remap, Forge 007p DV, Red DogBush, Milltek non-res, Lowered 35mm Apex springs, Badger5 TIP/cone filter/heat shield, Powerflex'd, Large FMIC, Relentless Downpipe, Parsons Decat and lots of love.
    On gearbox number 4.
    Further modification to come..
  3. #42
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    How you getting on?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
  4. #43
    Nov 2011
    Horsham
    389
    Little update, I finally have pretty much all the pieces now. The HU and blanking grommets for either side of the ESP arrived today.
    Have got the sat nav puck aerial too. I assembled it together loosely to make sure that I've not missed out any pieces.
    The only thing that's missing is the hazard light switch now. I thought I'd get away with using my existing pre-facelift one.. But I've just offered up the new fascia and it's actually bigger than the facelift so will be needing one of those too, d'oh!
    I've offered up the sat nav unit I bought, and can see that it's not an 8L one, and will either need some filing down the sides and a strip putting in above it (as informed, and expected to be the case), or will need to swap with an 8L unit.
    Couple pics:
  5. #44
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Re: S3 8L Double DIN conversion
    Can you not swap the fronts of the hazard switch over like the B5s?
    Saves doing the wiring.
    Can you fit it but wait a month or so while you check eBay and spam forums looking for a swap or a proper 8L unit and then sell your B5 unit for a profit?
  6. #45
    Nov 2011
    Horsham
    389
    Hopefully Scott. I'll have to see what the new switch looks like when I get it!
    Im tempted to wait till I can get an 8L unit before starting anything.
  7. #46
    Feb 2012
    68
    there is a facelift hazard switch on ebay right now:
    AUDI S3 HAZARD SWITCH A3 MK1 8L0 941 509L | eBay
  8. #47
    Setting the Standard
    Feb 2013
    Cape Town
    Hi guys, im new to the forum, i am also planing to upgrade my prefacelift console to a double din style unit but i would like to keep my Climate control unit, I have a dvd headunit fitted st present but its not flush and it irritates me does any one know where i can source seat leon 1m double din as it has the same dash as the a3 and it fits with minimal modifications.
    my current centre console
    what im looking for (Seat leon 1m centre console)
    apologies for the thread hijack, i didnt want to create a duplicate thread on the same subject
  9. #48
    Nov 2011
    Horsham
    389
    Thought I'd give a little update as have been fettling over the last week or two at slow pace.
    After scouting the 'bay for ages and not being able to find an RNS-D for 8L I decided to 'make' the one I already have fit.
    After some careful sanding with a more aggressive paper, and then fine grit to smooth it out, I got it to fit.
    It's not immaculate, but looks relatively good and I could always replace it with an 8L unit at a later date if one pops up.
    The only real issue is that (as I was warned) it left a gap at the top here:
    I was tempted to get a thin piece of aluminium and fit it at the top, but saved the hassle and instead opted to trim a piece of leather I had and fold a seam and fit it in place instead:
    Again we aren't talking perfection, but it looks presentable enough, and later on if I do get an 8L unit I'll just swap it over.
    Oh, and if anyone has a knack for getting radio codes without paying for the privilege I'd be grateful if they'd send me a PM with mine
    Here's the code:
    ~James
  10. #49
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Quote Originally Posted by Routledge View Post
    ooo and me. I got 2-3 units that needs codes.
    Routledge, I was thinking about you the other day.
    I should have given you my broken faceplate to cut apart, you would have removed the broken bits and i'd end up with a perfect faceplate.
    Looks like a tidy job though mate.
    How different are the B5 facelift top trim panel to your A3 unit?
    Cause ours is longer by about the amount you need.
  11. #50
    Nov 2011
    Horsham
    389
    So I phoned up Audi today trying to get the radio code and apparently their process is to get the chassis number of the vehicle and submit the request alongside the serial number of the unit.
    I explained the situation and the guy was pretty cool, and basically said to give him the chassis number of my car and the serial of the unit and keep fingers crossed that its right. If it comes back with a result I can always just check the code against my existing unit's code and if it matches then I'll be 90% sure that I've been given the one for the single DIN already in the car.
    He didn't mention a cost either which is promising, just said when he gets 5 minutes he'll fire it over and see what comes back and took my mobile number.
  12. #51
    Nov 2011
    Horsham
    389
    Winner! Got the code, and it was free!
  13. #52
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Dude, amazing.
    ask him if he can get any more. lol
  14. #53
    Nov 2011
    Horsham
    389
    I've just spent an hour pulling out the pre facelift single DIN unit, and then offered up the face lift double DIN.
    Everything is different. EVERYTHING.
    Only about 10% of the plugs are the same.. I'll take some pictures of how silly wrong it is and upload them when I'm done putting the single back in.
  15. #54
    Nov 2011
    Horsham
    389
    I took a few pics as I was plodding along.
    The old console removed:
    The moment I realised things were probably not going to fit:
    Now for a list of plugs that wouldn't fit..
    The cigarette lighter power supply plug:
    The pre facelift plugs at the top (left to right: ESP, hazard light, rear demister)
    The facelift plugs (ESP, hazard light, rear demister part of climate control unit on facelift)
    Given the facelift slots at the top.. This is the ESP plug that would need to go in it:
    Pre facelift, and facelift in the background - Climate control. Please note the extra slot on the lift for the facelift.. This is where the de mister plug needs to go.
    This is the plug that's meant to fit in there!
    I was going to put the unit in and just wire up the things that don't work later.. Until I realised that the following wouldn't work:
    - Rear Demister
    - ESP button
    - Cigarette lighter
    The only thing that would work would be the hazard light switch, as the plug is the same.. and the head unit, once splicing in a safe feed.
    On this basis.. I put the single DIN back in:
    I then took the car out for a ragging to teach it a lesson for being a PITA.. and it retalliated by blowing a coil pack:
    I'm now firing on 3 cylinders till this afternoon when I replace it.
    FML.
  16. #55
    Apr 2013
    Quote Originally Posted by Dicky A View Post
    Biggest part is getting round the aircon issue. If you can solve that then everything else is achievable with 'off the shelf' bits.
    Here's my facelift double DIN set up using a Kenwood DNX unit - apart from a simple fascia adapter plate everything else is stock. I usually hate after market stuff but it fits so nicely and does so much that I really can't imagine the car without it.
    Sounds awesome through the BOSE system and does everything - nav, bluetooth, iPod dock, CD, DVD, TV - love it long time!
    Hey guys, I'm trying hard to find a A3/S3 8L fascia adaptor for a 2 DIN aftermarket radio I have, but I just can't find one, anywhere. I know for sure that you can actually get one, cause I've seen a couple of pictures over the internet (like the ones above) where there are 8L A3's with aftermarket rádios installed. My car is a 8L S3 facelift from May/2003, I currently have a Symphony II unit in place. Can you people point me in the right direction, please? Sorry for the off topic. Good luck with your work...
  17. #56
    Mar 2013
    30
    I also need above
  18. #57
    Platty's Avatar
    Aug 2013
    7
    I'm just going down the same road swapping a single DIN to a double DIN on a facelift A3.
    I've bought an A4 adaptor face plate which will require some fettling to shoehorn in. The AC controller I'll need to change, but I'll first see if the sides can be trimmed to match the curve where the cubby hole compartment sits, then work out if it can be fixed back in.
    I went for a Kenwood DNX520BT (with square edges) as it has the twat nav built in, can be colour coded (nothing worse than a multi coloured dashboard) and is touch screen. A fairly good package all in all. there's also a reverse camera to fit and then swap the speakers for a pair of Infinity Components up front and possibly a pair of speakers in the rear quarters in custom pods.
    Current stable
    02 A3 1.9TDI Quattro sport - Daily hack
    08 MINI Cooper S - Showcar
    00 VW Polo 1.4 16v - Girlfriends thrash
  19. #58
    Drewvic's Avatar
    Nov 2013
    North yorkshire
    203
    have one of these for sale if anyone wants one??
    1.8Q sleeper all the way
  20. #59
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Facelift centre console? Or Leon 1m?
  21. #60
    Drewvic's Avatar
    Nov 2013
    North yorkshire
    203
  22. #61
    Sep 2013
    35
    I took a few pics as I was plodding along.The old console removed:The moment I realised things were probably not going to fit:Now for a list of plugs that wouldn't fit..The cigarette lighter power supply plug:The pre facelift plugs at the top (left to right: ESP, hazard light, rear demister)The facelift plugs (ESP, hazard light, rear demister part of climate control unit on facelift)Given the facelift slots at the top.. This is the ESP plug that would need to go in it:Pre facelift, and facelift in the background - Climate control. Please note the extra slot on the lift for the facelift.. This is where the de mister plug needs to go.This is the plug that's meant to fit in there!I was going to put the unit in and just wire up the things that don't work later.. Until I realised that the following wouldn't work:- Rear Demister- ESP button- Cigarette lighterThe only thing that would work would be the hazard light switch, as the plug is the same.. and the head unit, once splicing in a safe feed.On this basis.. I put the single DIN back in:I then took the car out for a ragging to teach it a lesson for being a PITA.. and it retalliated by blowing a coil pack:I'm now firing on 3 cylinders till this afternoon when I replace it.FML.
    Mate i spent about 3 hours today trying to find a way for making it all fit, im in exactly the same position as you. Its so fuc king annoying. The only way around it is to probably get the loom plugs of a facelift and to cut and solder every single 1. Im just going to have to try and sell my double din screen and goto a flip one instead unless someone can shed any light. Waste of time and money and now ive gotta try sell my double din screen and try look for a half decent flip 1. Not a happy bunny at all!
  23. #62
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    I think the only way is a Leon double din. I don't fancy cutting the wires, not worth it'
  24. #63
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,788
    I'm also gathering the parts to do this soon. Came across this: http://www.audizine.com/forum/showth...celift-upgrade
    Gops and Cj_sat69 like this.
    <Jay A3 build thread>
    241bhp K03s - R Tech
  25. #64
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Spot on jay! What a good find!
    Jay A3 likes this.
  26. #65
    Sep 2013
    35
    That is a wicked find, ill have to try out the climate control stuff hes shown there. Fingers crossed it will work.
  27. #66
    Jun 2012
    Essex
    215
    Got home early from work today so thought id give this a crack.
    im not doing the double din conversion, but just pre to facelift conversion.
    Problem I've found is in the a4 post, it shows the illumination pin missing from the 12 pin plug......mine is already there, but still won't illuminate.
    Ive got a mate with a facelift s3 who has kindly said i can borrow it for the day and to check and log what each wire does.
    As soon as i have an answer, ill let you all know.
    Its purely the ac panel thats causing me headache. Hazzard is like for like swap, demister switch just needs 2 wires extended, and ash tray light will be easy too.
  28. #67
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Did you switch your lights on to illuminate it?
  29. #68
    Jun 2012
    Essex
    215
    Yes fella
    I've got a horrible feeling the ac panel I've bought is faulty, so will plug it into my mates s3 when i get hold of it
  30. #69
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,788
    Bump
    Anyone got any further on the AC unit issue? My pre facelift AC unit works. Swapped the facelift one over and nothing... No power no illumination. I also thought it could be the unit may be faulty so I borrowed another one that I know works. Still no joy...
  31. #70
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Did you pick out pin 6 on connector A for illumination?
  32. #71
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,788
    Pin 6 is already populated with a wire. There's no power at all to it.
  33. #72
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,788
    Both Hvac units. Looks exactly the same apart from the rear demister plug on the face lift unit.
    Facelift on the bottom
    Preface lift on top
    From left to right
    Plug D = 16 pin
    Plug A = 12 pin
    Plug B = 20 pin
    Plug C = 16 pin
    Scottb5 has had a look for the wiring diagrams on Elsa win for me but we are struggling. Plugs may be the same but pins look like they may be routed differently which is strange as the b5s are a similar setup and they were plug and play... Can anyone shed some light on what pin is what for both units?
  34. #73
    Feb 2014
    19
    Is the process/setup the same in the S3 and A3?
    I have just bought an A3 and need to clean up and refresh the interior a bit and would like to Double Din it as well, so this is all quite interesting.
    When was the S3/A3 facelifted? Or was it just the S3 facelifted?
    Mine is on an '02 plate, which is quite late I believe for the 8l chassis so I am assuming would be facelift?
  35. #74
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,788
    Yours would be a facelift. I think they were from 2001 to 2003...
    I think yours would be much simpler to go from single din to double din. New double din cage and new lower hvac unit - plug and play as your wiring is the same
  36. #75
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    I got no idea why yours is so hard mate.
    Its stupid.
    B5, which looks like it uses the same units with different faces, same plugs is just a simple plug and play.
    I can't see why they would completely change the wiring on a A3.
  37. #76
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,788
    Me either. Thanks again for your help yesterday. I think I will need to identify each pin starting with the power and seeing if both are located in the same place....
  38. #77
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    You got the diagrams but I don't understand where the other plugs are.
    It only lists some and no idea what the 10 or 17 pin plugs are.
  39. #78
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,788
    Yeh I'm going to get someone who knows electrics better than me to see if he can make sense of the diagrams
  40. #79
    Feb 2014
    19
    Quote Originally Posted by Jay A3 View Post
    Cool, cheers mate. Let's hope so. Anyone know part or model numbers on the lower HVAC units? Just to make it easier to find on eBay. Lol
  41. #80
    Stalking Kate Beckinsale
    Nov 2011
    Farnham
    52
    Guys, I have a brand new double DIN cage assembly available and the correct HVAC unit for it (albeit with beat to hell buttons sadly, took me 9 months just to get this) that I don't need as I never got around to doing the conversion and am selling the car.
    8L0 858 005 A - Cage
    8L0 820 043L - HVAC
    MiniMetro <1.1 Escort <1.6 Escort <106 XSI <106 GTI <WRX <STI2 <STI5 "Fluffy" <Evo VII "Helga" <XJR
    "Brutus"- RS6- MRC stage 2- Milly non-res+ sport cats- PSS9- H&R ARBs- OZ Superturismo LM/Michy PSS- 547PS/826Nm
    RS4 - Milly non-res- TTRS Wheel- SDS- BT- Latest Gen RNS-E- F1 Asymm2
    S3 BAM- MRC stage 2- Badger5 TIP+ shield+ cone+ phenolic spacer - Milly non-res + AmD sport cat- F1 Asymm2 - 283PS/411Nm
    Audi Technical file archive - http://bit.ly/TZ2hJb
  1. double din conversion
    By slight_problem in forum In-Car Entertainment
    Last Post: 10th December 2007, 12:30
  2. Double DIN Conversion
    By IngenLimits in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2007, 09:46
  3. Rear window heater + double din conversion
    By mordz in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2007, 18:43
  4. Single to Double Din Conversion
    Last Post: 19th March 2007, 11:18
  5. Single DIN to double DIN conversion
    By moogie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th October 2005, 20:38
