Chris NottAH Fabrications
Results 1 to 35 of 35
    kelk11's Avatar
    Feb 2009
    102
    Lower tie arm snapped whilst driving
    Driving home earlier, drove around a corner and over a grate to hear a ding followed by a massive drift. Thought it must be ice on the road. Carried on driving but the car started to snake so stopped pulled over.
    found this
    so will these do?
    Audi A3/S3 Quattro MK1 S/S TIE ARMS (PAIR) | eBay
    Do I also need separate bushes? Thanks.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    They will be fine mate, you also need to look at changing the bushs in the hub, they seize up and thats what causes the tie arm to snap, audi have done a revised part that stops this from happeneing, have a search on here for rear hub bushes, if you cant rind it ill post the part number when im back home tomorrow.
    kelk11's Avatar
    Feb 2009
    102
    1J0505203 from searching this seems to be the one I need?
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Is everything else ok? No bent shocks or anything?
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    kelk11's Avatar
    Feb 2009
    102
    Don't think so as once its jacked up, everything seems to line up as it falls back into place. Watching it get dragged onto an aa recovery truck with the wheel like that made me massively cringe and feel slightly sick ha. If the suspension is damaged and now the fact ill get adjustable tie bars, what an excuse to upgrade the springs and shocks anyhow
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Oh, that's good then. I'd be worried everything would be buggered but like you say, a good excuse to upgrade.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Ill check tomorrow.
    You need to be getting the rear diff checked after that mate, something like that can cause serious issues, make sure you or a garage give it a proper looking over and make sure nothing else has been affected.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    hmm 2nd one in a week......ASN's Pub
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    I need to hurry up and get my bushes fitted, dont fancy snapping your tie arms dave, seeming their now like rocking horse ****e lol.
    Apr 2012
    605
    Re: Lower tie arm snapped whilst driving
    I have these mate brilliant set
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Cheers Dan but i honestly think they would not snap them buggers....the sussy would just go rock hard..
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    If your in standard suspension you don't really need adjustable tie arms . I got a full set (4 arms) including bushes, nuts and bolts etc for around £90. Although its a good investment if your considering going lower in the future.
    S3 Big Turbo
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Damn the UK is hard on cars eh? Salt on the roads, the cold etc. Must be worse for these rose joints too. Luckily all 4 of mine were free moving (but uber stiff).
    kelk11's Avatar
    Feb 2009
    102
    Massive thanks to s3dave, should be all sorted tomorrow!
    Apr 2012
    605
    What have you gone for ?
    kelk11's Avatar
    Feb 2009
    102
    Gone with a used oem tie bar just to get the car back on the road for now. Will upgrade when or if I sort the suspension out and of cause save some money.
    Apr 2012
    605
    I had spare ones what they set u back ?
    Feb 2012
    bedfordshire
    749
    What are those ebay tie arms like on the first post ? might get them not a bad price. I need to sort my rear end ASAP my creaking of the seized rose joints has got worse with all this bad weather, and my car is lowered so I need them really
    Apr 2012
    605
    The blokes who make them no they stuff you do get bait of road noise but doesn't bother me
    Feb 2012
    bedfordshire
    749
    Ok cool just came across these to but not sure ? the thing is I have a new set off 4 tie rods and rose bushes
    Audi S3 & Quattro (99-04) 'Camber Adjust' Rear Arm/Tie Bar Upper Inner Bush Kit | eBay
    27,099
    Mine did this on the revised part aswell, was totall shocked years back when I was driving 5mph over a hump in road & it went, problem was the bearing cage cracked on that side, so as said check the rear drive to be sure no other damage.
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    Those compbrake ebay tie arms are a good price , Online shops have them priced at £240.
    S3 Big Turbo
    kelk11's Avatar
    Feb 2009
    102
    so the car has been repaired today, mechanic said the rose joint hadn't seized and was fine but the other end was a nightmare to remove. new tie arm seems to have sorted the camber from -2 to 0 from looking at it.
    no damage to report other the than the arb had popped off somewhere but is fine now.
    taken it out for a spin tonight just to check everything and i now have fwd :-( what should i be checking?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Check the earth strap to the haldex.. if no joy come up on saturday for a scan...(assuming you have not got VCDS?)
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Needa scanning mate but from something like that it could have damaged the diff, haldex unit etc.
    kelk11's Avatar
    Feb 2009
    102
    thanks Dave, ill pm you nearer the weekend in the mean time ill get my head under and look to see if the earth strap is intact.
  28. #27
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    198
    Do people put the adjustable arms on the top or bottom?
    REVO Stage 2, Eibach anti roll bar kit, forge 007p diverter valve (yellow spring), Badger5 turbo intake pipe with Jetex filter and Neuspeed heat shield, Forge upper bost hoses, N75, DV and Cam breather hoses, XS Power 3" downpipe 200cell cat and 3" cat back system, Apex 30mm springs, N249 bypass, Oil catch can and PVC delete, Front Mount Intercooler............
  29. #28
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,524
    Quote Originally Posted by scotty_24 View Post
    Any is ok, bottom ones are easier to replace than top, I would say bottom is the more popular position, since it's easier access, and usually the ones to snap off!
  30. #29
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Or do what ive done and buy 2 sets so you can have them on the top and bottom lol.
  31. #30
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Yeah and avoid having to bugger around with changing bushes etc
  32. #31
    kelk11's Avatar
    Feb 2009
    102
    so a bit of an update, Dave scanned the car for me and it came back with the following code
    01155 - Clutch
    04-10 Mechanical Malfunction - Intermittent.
    had a search around various forums with out a conclusive diagnosis. some people have changed the precharge pump to fix this issue, I don't think its that. Others have had to replace the haldex and diff, this seems more plausible due to the strain the tie bar snapping will have placed on the diff.
    anybody have any experience with this fault code and what did you do to fix it?
  33. #32
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    my stepdad is a recovery driver and I remember when the 8l was not far off new I was with him picking 1 up with a broken tie bar, as he pulled it on to the back of the wagon, the other side snapped as well. I don't fancy 1 braking on me thanks.
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
  34. #33
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I would start a new thread About "Haldex issues" mate..
  35. #34
    Wingnut Express's Avatar
    Audi sponsored by Mastercard
    Feb 2008
    Surrey
    125
    Same thing happened to me late Friday on the M54, luckily I was only doing 60mph when it gave way! Bloody exciting couple of seconds holding on to the steering wheel!
    Have had to have it recovered to my in laws house 120 miles away in North Wales, but they have no local garage in their village.
    I have ordered a pair of KW adjustable replacements as the car is lowered 30mm and will have to install them with the car on axle stands, but as I didn't have any tools with me I could check what size tools I would need, so does anyone know what size sockets and spanners I will need? Also as I can't get it aligned straight away should I temporarly set them up to the same measurement as the opposite side. (Using a tape measure)
    Thanks guys
    Ian
    Worried that one day I may have to buy something sensible, but until then!
  36. #35
    kelk11's Avatar
    Feb 2009
    102
    Just a quick update to this thread, having come to the conclusion the diff was damaged, i've had it looked at on a ramp today and the driveshaft was damaged at the cv end causing the shaft to spin freely as it had worn smooth. 1 new driveshaft later i now have power to all 4 wheels again. :-)
  1. Rear tie arm snapped?
    By Oke Phill in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2012, 21:20
  2. urgent advice please... lower suspension arms
    By bouncer--daz in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2007, 16:15
  3. a3 quattro lower suspension arm bushes
    By dantheman1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2007, 11:46
  4. constant sound whilst driving
    By ravi in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2005, 08:49
  5. adjusting rear tie arms?
    By Banwell in forum Handling
    Last Post: 3rd April 2004, 10:24
