EM TuningJMB Retrofits
Page 2 of 2 FirstFirst 12
Results 41 to 43 of 43
  1. #41
    RIP S3dave
    May 2004
    nr Glos
    7,199
    115 shows requested and actual boost.. dougs 118 is also a valid boost to read.
    you have some boost creep..
    not sure what you are asking now.
    unknown map, unknown tune.... who the in factual hell knows dude..
    just log the single block.. 115 OR 118, whichever and do a 3rd gear pull from 2krpm to 6krpm and a better data log will be seen.. confirming the actuator and any creep...
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  3. #42
    beachbuggy's Avatar
    Surrey
    1,746
    Darren where abouts are you located?
  4. #43
    Sep 2012
    West midlands
    368
    Quote Originally Posted by beachbuggy View Post
    halesowen in birmingham i have a pressure tester coming today is it possible too upload a video its took me 2 months too suss uploading a log with copy and paste pmsl my actuator is my problem 100 percent no creep im sure i have logs too prove the actuator is causing the creep why is map asking for 2440 range now were as in othere logs previously it was asking for 2550mbar and turbo can make it easy enough at 4000rpm???but cant set it back there as if i do when i reach a higher gear i get creep and overboost condition so no consistant boost badger is right it is creep but due too a misalighned actuator if you hold the actuator in one hand and pull rod all the way too one side hear it click out of position!!!!!this is causing flap too close on hard boost pressure or not opening enough in my case!!!
  1. Requested MAF and Actual MAF values
    By Illusion-Paul in forum Diesel forum
    Last Post: 3rd July 2012, 10:00
  2. Boost control issue? log inside...
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2012, 09:41
  3. Requested boost VS actual boost, is this normal?
    By James333 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd May 2012, 18:38
  4. 17705 + car not making requested boost
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2010, 17:34
  5. Actual boost VS Requested boost
    By imported_SYNAPS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2004, 18:14
