boost log can any one help
darren t
West midlands
160020.3980103087.9172044.43.065.4488.210000
21609.898099088.81140014.31.72.0389.120000
236053.4980101089.71224041.44.4220.4290.020000
256076.71150115090.63240061.75.7830.1990.930000
2840112.82300135091.55264080.57.1442.7291.830000
3320191.72360212092.432960130.112.2482.6192.740000
4240191.72360234093.343640191.721.08184.1793.630000
4680191.72380223094.254280191.719.72159.4494.550000
5280191.72360228095.154840191.719.04183.4795.450000
5800191.72380225096.065440191.720.06210.5696.360363
524012980133096.96596018217.34224.1497.27000 0
436087.21510113097.87488012.81.74.598.170000
4480191.72070221098.774360136.812.58133.1199.0700.85.30.8
4760191.72040230099.68460019116.66168.8199.9800.85.30.8
420012.89801220100.584720160.912.92166.31100.880000
332013.59801030101.49392012.81.363.69101.790000
340033.89801000102.3934801208.39102.690000
332010012801280103.3336045.94.7631.97103.6002.30.8
332093.213101310104.3332089.57.8253.94104.61000.83.8
332096.210901320105.21332095.58.8460.53105.51000.83.8
i do have logs before engine rebuild same turbo boosting and map was asking for 2550 mbar boost i have adjusted actuator off but wouned it up too much and hit overboost so now i have undone a couple of turns my concern is it backed off at 5800rpm and my boost is more than requested in low gears but not enough when on full throttle and why is the map only asking for 2380 max??? i have logs were it asks for 2550mbar??? before rebuild no faults on vag.com hybrid stage 2 turbodynamics ko4 3inch down pipe forgedrods acl racebearings 3inchtip 200 cell race cat too miltek non resonated sounds awersome lol i have added 1.5 degree extra timing before this log via unicode have taken off now but havent done anymore logs new lama sensor pre cat maf n5 n249 delete all hoses vacume ect forged pcv valve new!!! vacume booster new no leaks when blown through any ideas much appreciated and air flow is excellent with b5tip big improvement as i borrowed my mates as his car off road for rebuild!! before i get my own, too do these logs before i maxed 218gs at 7000rpm now 224gs at 5900rpm !!!!!!!!!!!!!!!!!will be buying one very soon car backed off is it my extra timing advance or actuator need tightening a little more?
here are several logs from previous build!!!!
200036.3665.1188.4200008.72224014.39901070
220047.5689.816.59.330001.59.63212092.516501200
252070.6794.91210.233001.510.542400122.624201520
3000127.0699.6-311.133004.511.442800171.424902080
3520127.811002.312.142.3004.512.45336018824402350
4040150.97100613.052.3003.813.353840191.723902320
4560173.5310010.513.951.530314.264400191.724502320
5040183.1999.29.814.861.5332.315.164920191.724202300
5520195.6110010.515.774.5665.316.07536018824102250
5920204.2210011.316.684.5665.316.975800178.922802200
6240205.8610013.517.583.85.35.34.517.886160175.221602080
656020382.41218.493.85.35.37.518.786440169.920402030
'003Group B:'020Group C:'115
RPMMass FlowLoadIgn. TimingIdle StabilizationIdle StabilizationIdle StabilizationIdle StabilizationRPMLoadAbsolute Pres.Absolute Pres.
TIMETIME
/min g/s % °BTDCSTAMP°KW°KW°KW°KWSTAMP /min % mbar mbar
132016.0615.3180.2800000.57104051.9990980
152019.9216.913.51.1700001.47160063.29901030
148018.6915.310.52.0900002.39124067.79901080
208020.5813.7272.9900003.29188056.49901100
268018.5612.229.33.8900004.2248060.99901100
19609.729.4334.800005.12160159901050
192033.8983.9185.700006180075.215101060
244056.9492.916.56.6100006.91224010016101280
28400.533.5-3.87.5200007.82288011210201560
61205.567.58.319.3837.58.37.519.7656036.19902310
5000184.47100920.2901.50020.594960169.222802000
50001.036.3321.234.53621.55080101.511001900
39608.896.7322.1000022.4424013.59901090
36808.946.3323.01000023.33720129901020
35208.565.93.823.91000024.213600129901020
33608.866.32.324.81000025.11340013.59901020
31608.175.92.325.72000026.02324013.59901010
30408.035.92.326.63000026.93308012.89901010
29607.925.51.527.53000027.83300012.89901010
288022.4415.330.828.44000028.74288014.39901000
284028.1916.93029.34000029.64284048.19901030
280027.8316.930.830.25000030.55280049.69901070
280043.0322.425.531.150.82.30.83.831.45280066.910401100
276037.9420.825.532.060.82.30.83.832.36276072.210201280
272033.2818.82732.960.82.30.83.833.27276066.99901260
26803.364.733.833.870.82.30.83.834.17272054.99901190
