Sky InsuranceVolks Autos
Results 1 to 7 of 7
    James TQ's Avatar
    Apr 2012
    Essex
    548
    LIVID! manifold stud snapped!
    over the last few weeks iv had a blow in the exhaust, i was fitting my new TIP today and checked the mani bolts, the top one above the turbo was lose, when i turnt it the stud was turning too, i dont know how it happend or how long its been like it,
    whats the best way to get this sorted and does anyone know costs... be easy on me!!
    thanks!!
    would a a3/mk4 gti head fit, would this be a better option to try source a new head?
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,378
    Assuming by your name it's a 1.8 turbo quattro sport not an s3?
    James TQ's Avatar
    Apr 2012
    Essex
    548
    yeh a a3 quattro, so ko3 turbo
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,355
    hang on a minute. You said the stud turned, how do you know it's snapped?
    It's fairly common for studs to back out with the nuts, and you certainly don't need a new head!
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,061
    Visit 16Klappe's Instagram Channel
    Man up, be patient and get a decent mechanic. Head doesn't need to come off at all if the stud is snapped assuming it's one of the top row; not even the manifold has to come off in that instance.
    First thing to do is buy some Plus Gas; don't bother buying anything else only Plus Gas. Spray in the hole in the morning when you start the car and in the evening when you get home until you come to the point of needing to remove the broken stud. It'll make it A LOT easier.
    If you take it to a garage and they say the head has to come off; then move along because they're not competent enough to be doing it.
    I had 2 snapped studs on my last A3 which had been in there for 200K; my dad took 4 hours with a right angle air drill, left handed drill bits, easy outs and +gas and we got them out. It wasn't easy at all...But it is possible as long as the person doing it know's what they're doing.
    Hopefully this will give you hope, it's hardly the end of the world -
    I quite often say I'm going to do things.
    Then never do them.
    James TQ's Avatar
    Apr 2012
    Essex
    548
    at least the head dosnt have to come off!! and i was turning the nut and stud was turning too....then it pulled out, nut and stud tiny bit of thread on the end, i cant really get to it without taking the ic hard pipes off and fiddling between the puck and DV ect... thanks for the replies....
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,061
    Quote Originally Posted by James TQ View Post
    So it's on the top run of nuts, good
    You'll have to remove the charge pipe and the brackets which hold it, that's a 10min job. Then the rest of it is just patience
    I wish you the best of luck!
    Then never do them.
  1. S3 Exhaust Manifold Studs.
    By MarkyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2012, 18:09
  2. sheared stud in exhaust manifold to turbo
    By kaos in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2012, 16:58
  3. Exhaust manifold gasket, studs and nuts.
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th April 2010, 16:30
  4. Garrett manifold
    By saldale in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2003, 13:38
  5. Polished inlet manifold
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2003, 01:00
