Sky InsuranceBadger5
Results 1 to 21 of 21
    S3 Paul's Avatar
    Oct 2006
    2,764
    Strange Question after fitting catch can...
    I fitted a custom catch can a few weeks back now with the outlet currently vented to atmosphere.
    It was time to check the car over and mini service before winter... I thought this would be a good time to empty the catch can?
    So... i wedged a small cup under the drain plug...unscrewed it.
    Nothing came out. Nothing at all, Is this normal? I expected at least a splash, But nothing .
    Noggy Blue 2001 S3
    Oct 2012
    Farnham,Surrey
    6
    I have had nothing out of my catch can in the 3 months ive run it.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,500
    Quote Originally Posted by rustya3 View Post
    Hi, welcome to audi-sport.net. Any pics of the car? Where are you located? Enjoy the forum. x
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    should have a little bit, even if its just a oily/watery mixture.
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Depends on wether and how the catch can is baffled as alot of the unbaffled ones will let most of the vapours pass straight out the outlet before condensing to a liquid
    Would expect to still see some in there though?
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Mine is unbaffled and also venting to atmos and been on about 6 weeks and is half full so gonna empty it soon. So surprised youve got nothing in yours are you sure its all fixed up right?
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Oct 2012
    Farnham,Surrey
    6
    I have had oily residue in there but nothing enough to drain,Mine is a home made can I turned up on the lathe and has the full size inlets and outlet it also isnt baffled and steams constant when the car is upto temp on tickover.
    Feb 2012
    bedfordshire
    756
    After 2000 miles I had about 50ml of oil water mixture so not alot how long have you had it on ?
    S3 Paul's Avatar
    Oct 2006
    2,764
    Mine is un baffeled, But there is no residue at all where the outlet is. its strange every where is dry. I can feel air passing through the catch can. but therejust seems to be no mess. Wierd? or ok?
    Noggy Blue 2001 S3
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    If unbaffled i would be sure it would fill with condensate,,,,so yes weird..i get oily watery mixture out every week ..about 50ml
    Yohan87's Avatar
    May 2011
    405
    I've been emptying loads out of mine and that's 1 year it has been installed.
    Mine doesn't vent to atmosphere though, it re-circulates back in to the TIP and I wonder if that results in more being sucked through when on vacuum.
    When it's cold up here my catch can has been known to almost fill up in 3 weeks.
    Oct 2012
    Farnham,Surrey
    6
    I would expect a Baffled can to collect water and oil mix which is its purpose to stop it re entering the tip,the way I look at it the hot steam has no restrictions on a non baffled can so exits with no hold ups but the baffled slows the flow so cools and stays inside. Or am I talking waffle as usual lol.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,284
    Mine didn't fill up at all when I first fitted it, then I realised the drainage screw wasn't done up and I'd been oiling my subframe
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Sep 2012
    Colchester
    90
    I only installed mine last night. And after only 80 miles i have a small amount of water in there. Was only a tiny amount though.
    Mines been baffled with synthetic wire wool from homebase.
    Audi S3 [AMK 1.8T]
    Mods:
    N249 Bypass
    Revo STG 1
    Rota Grid Drift 9.5J alloys
    AP coilovers
    PCV oil catch can (to atmosphere)
    Alex C's Avatar
    Lizard, Cornwall
    2,606
    Quote Originally Posted by Westy View Post
    saves it from rusting i guess
    do you see less oil in the can after changing it from vented to TIP to vented to atmoshere Westy?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Westy's Avatar
    Dec 2008
    17,284
    Quote Originally Posted by Alex C View Post
    About the same I'd say.
    S3 Build Thread
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    As i was fitting my new filter today i took the opportunity to empty my catch can for the first time.
    Its been on for about 2-3 months now of which i first vented to the TIP and have since changed to venting to atmos. The catch can was about 3/4`s full so about 200ml of stuff, most of which seemed to be condensation that has reformed into water plus some oily mayo type stuff too. All cleaned out and but back together so will check it again in a couple of months.
    Westy's Avatar
    Dec 2008
    17,284
    Quote Originally Posted by vrbob View Post
    Keep an eye on it over the cold Months bud as it does fill up quick.
    S3 Build Thread
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Cheers for the TIP westy,
    i guess the cold weather makes for more codensation then hence it fills up quicker
    Defo happy that all that gunk and water isnt heading back into my TIP anymore too
    Westy's Avatar
    Dec 2008
    17,284
    If you were to take the boost hose off at the throttle body it should be nice and clean. That's what it's all about
    S3 Build Thread
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    yup i took off the throttlebody and cleaned it all up about a month ago (never done it before on this car) so had 10 years of crud on it and some oily residue etc but with a bit of electrcal cleaner and some elbow grease and it was looking nice and proper shiney when it went back together. So will do it again in a few months time and hope to see it all shiney still
    To be honest the most surprising place i found loads of cruddy oily stuff was in the old SMIC`s when i took it off to put my FMIC on!
  1. Quick question for the Catch can hero's...
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2012, 11:34
  2. DV noise after fitting Catch Tank
    By rhubarb4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2011, 17:42
  3. A Few More Catch Can Fitting Questions??
    By A3 T in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd September 2011, 16:24
  4. For those that have fitted catch cans
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2010, 12:20
  5. Strange noise after fitting Milltek sport exhaust
    By RGC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th February 2010, 17:59
