Sky InsuranceBadger5
    Jan 2012
    68
    overboosting problem 1.8t agu
    my car is chipped and should boost 1.4bar,for a while it boosting 1.6
    i disconnect the two electricity wires that connected to the n75 valve and went to test drive
    now instead of boosting 0.5 bar the car still boost 1.6bar!!!
    any ideas?
    Lewis583's Avatar
    Mar 2010
    872
    Check all vac pipes on the same line as the wastegate actuator
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,377
    sounds like the pipe from the actuator to wastegate has come off somewhere, or possible from charge pipe to N75 and causing a boost leak as well.
    that's the only explaination if you're getting above actuator pressure with the n75 disconnected
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Actuator damaged /semi siezed...... wastegate siezed/partially siezed .........bent actuator rod....
    Jan 2012
    68
    how to check the actuator?
    Jan 2012
    68
    ok i just checked the hose from actuator to the n75 and was cracked , the rubber was hard like a rock o_O!
    lucky i have a tons of silicone hoses from ebay, everything works great now .
  1. Overboost problem - advice needed after searching please!
    By Ads_AudiA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2012, 23:29
  2. 1.8t Overboost problems!
    By marrick92 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2012, 16:53
  3. overboost problems?
    By wibble111 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2007, 12:23
  4. 97 (P) URS6 with overboost /cutting out problem
    By smogthemog in forum General Technical / How To
    Last Post: 30th October 2006, 20:06
  5. N75J and limp mode (overboost problems)
    By pure in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2004, 18:52
