EM TuningVolks Autos
Results 1 to 8 of 8
    .Ben.'s Avatar
    Nov 2012
    Guildford, Surrey
    114
    Front ARB needs replacing?
    Just taken my new-to-me S3 for a check-up at a garage.
    On my drive home last night, I'd noticed a slight knocking noise from the front, present when I went over larger bumps.
    The garage have just told me that my front ARB bushes are shot and that I'll need to replace my whole front ARB at a cost of over £400.
    [Fitted ARB and Bushes = £350 / Full alignment = £90].
    Is this right? Are there any alternatives or is it something a competent DIY spanner-wielder can do?
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    Surely just do the bushes and drop links. I doubt the arb is broken? They're probably having you on...
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    May 2010
    Bedford
    2,877
    Fit the arb and bushes yourself and then just pay for the alignment. Its not a hard job just takes a bit of time dropping the subframe and so on. Save the money on the labour charge and spend a little on poly arb and steering rack bushes instead along with obviously a new arb.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    I had front and rear Golf R32 ARB's fitted 5 years ago and that was 500 quid,brand new not used ARB's btw
    .Ben.'s Avatar
    Nov 2012
    Guildford, Surrey
    114
    Thanks guys.
    It's not that they're suggesting the ARB is broken, just corroded at the contact points - apologies for not making that clear...
    The mechanic intimated that he could replace the bushes (£90 fitted) BUT if the ARB isn't replaced, the bushes will be compromised again in <12mths.
    @Jason: Just familiarising myself with this site -and this may be a silly question- but is there a 'How To' on replacing the ARB/ dropping the subframe?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    May 2010
    Bedford
    2,877
    Erm not sure. Dont think i`ve ever seen one myself? I`ve done it on my gf`s old Leon quite a while back but i just did it by getting under the car and just undoing whatever i thought needed to be unbolted lol.
    Edit: There you go above lol
    .Ben.'s Avatar
    Nov 2012
    Guildford, Surrey
    114
    Voorhees: Legend. Love you long time.
    Now all I need is a 'friendly' TPS contact... (anyone?)
  1. Movit front discs need replacing
    By Ashley g in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th July 2011, 10:10
  2. S3 Front ARB Bushes, expensive to replace?
    By Painey in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2010, 09:12
  3. is an aftermarket front arb needed when lowering on coilovers?
    By s3-mike in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2010, 20:27
  4. Replacement front bumper needed!
    By meatychi in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th March 2007, 19:24
  5. Front ARB - question for people that have had them replaced.
    By god_thats_quick in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2006, 23:15
