EM TuningAH Fabrications
    A3tell's Avatar
    Jun 2009
    essex
    239
    What's broken!!??
    So on my way home tonight, something decided to go wrong with the car, lost a big chunk of boost!!! And also my usual dump noise from my forge 007p has now turned into more of a flutter sound!!!! Now I can hear a boost leak from somewhere, but where wld b best to start looking from the symptoms I av described???
    Its a modified AGU 1.8t btw!!! Hope someone can help as got to take car to get windows tinted tomorrow afternoon!!!
    s3dave's Avatar
    mediator
    west yorks
    9,113
    Check the actuator pipe up to the n75 valve, also the orange charge pipe..
    A3tell's Avatar
    Jun 2009
    essex
    239
    It's not an s3 so don't av a charge pipe! Also I have upgraded to a forge tip, so I hope noting is wrong with that, as bit expensive to replace that!!! It's just the flutter noise I get now instead of my usual dump from the 007p which is baffling me!!! Surly that wld suggest a valve issue???
    s3dave's Avatar
    mediator
    west yorks
    9,113
    Ahh you still have a charge pipe, check under the car by the pancake pipe...
    A3tell's Avatar
    Jun 2009
    essex
    239
    Ok, but I have a fmic and I checked all that first!! Sounds like its coming from the back of engine bay somewhere!!! Am hoping it may just b a split diaphram from my oo7p, going to chuck my stock one back on n see if that sorts it!
  1. Replies: 2
    Last Post: 6th January 2012, 23:21
  2. Whats this broken thing?
    By roman3000 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2010, 14:03
  3. Broken Turbo, what options? (~£2000)
    By James333 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2009, 23:28
  4. What is broken ?
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th September 2008, 09:34
  5. whats this broken bit ?
    By cjhill in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2006, 10:43
