Sky InsuranceEM Tuning
    mark_S3's Avatar
    Yorkshire & Humber Events Rep
    Sep 2012
    Wakefield
    600
    S3 Window Regulator replacement
    Guys/Girls
    Yesterday i put the O/S window down and once it hit the bottom there was a loud 'crunch' type noise and before you know it, the window wouldn't go back up. So glad it was sunny in Wakefield yesterday as i had a ten mile journey with the window down.
    Anyway once i got home, i popped off the door card and found the window regulator cables have snapped. Now I'm presuming i just need to replace this as I'm sure the motor works because once you touch the switch the motor wants to move but cannot due to the loose wire cable wrapped around.
    So I'm going to order a new Window Regulator kit and replace that. Is that all i need to do? And how hard is it to replace?
    I've read up that i need to pop the old rivots out and can replace with nuts and bolts.
    Has anyone got a guide to replacing the regulator or can write a description of what to do, and also what bolts/nuts i need to replace the rivots?
    Any help would be much appreciated.
    Mark
    mark_S3's Avatar
    Sep 2012
    Wakefield
    600
    And also, yes i've searched the forum and found little help.
    Just like now. Tried to find out how much coolant is in the system as i plan on doing a full flush and renew the antifreeze with G12+, but after 45mins on the search function with 'coolant', 'antifreeze', 'fluids', 'G12+', etc and still i haven't found the simple answer.
    How much fluid is in the coolant system so i know how much G12+ to buy? I know its a 60/40 mix with water.
    Thank you.....
    WorkInProgress's Avatar
    Oct 2012
    Scotland
    237
    Add WorkInProgress on Facebook
    I'm interested in this too, have found some useful threads on this and have just bought this off Ebay, mine is a 5dr but I imagine fairly similar process. Had a look today and I think you'll need to remove the door subframe to get access to everything.
    Have a look here to see if that's of any use to you
    Alex C's Avatar
    Lizard, Cornwall
    2,599
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    mark_S3's Avatar
    Sep 2012
    Wakefield
    600
    Thank You guys.... Thats the info I needed, and now I have the stressful job to do.
  1. Front (RHS) Window Regulator replacement
    By necroeire in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th September 2011, 16:46
  2. A4 Window Regulator Problem
    By speedbird2639 in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd December 2006, 19:52
  3. Drivers window regulator
    By kenloen in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st October 2006, 11:05
  4. Passenger door window - regulator
    By funkycat in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th July 2005, 19:56
  5. Automatic Window Regulator Audi 5000 S
    By imported_jaw174 in forum Classic Audi Forum
    Last Post: 10th August 2004, 23:22
