Volks AutosJMB Retrofits
Results 1 to 11 of 11
    Oct 2010
    108
    wheel wobble over 60mph?
    hi guys got a slight problem i cant seam to fix ive had this issue since ive had the car really and its starting to wind me up ive changed all bushes the front arb 4 new tyres+balancing new track-rods and ball joints and had four wheel alignment done ive felt for play etc and cant find any car drives lovely but as you gather speed its just gets exaggerated ANY help will be much appreciated
    vlj
    Oct 2012
    If it gets worse with speed I'd imagine it is the wheel bearing..?
    '96 A3 1.8T
    Feb 2009
    Aberdeen
    2,621
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    Any spacers on? Cheap spacers will cause wobble. Also check the condition of the brake discs, if they're warped they'll wobble and could upset the wheels too.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    540
    i see you've changed the tyres, but have you changed the wheels themselves? Try swapping the wheels around and seeing if the wobble changes position. Balancing with new tyres won't necessary cure a buckled wheel - get them checked or try some other wheels if you can.
    I had exactly the same problem on mine, 4 new wheels solved it instantly
    Oct 2010
    108
    yes ive have had different wheels on and same thing my discs don't seam warped will check with a straight edge tomorrow and yes i do have 10 mm front and 15 rear spacers on and had the car aligned with these on would this be an issue?? thanks for your input fellas
    Feb 2009
    Aberdeen
    2,621
    Some cheap spacers can cause wobble, hubcentric ones shouldn't.
    Hunt is over
    Oct 2010
    108
    funny you should say that they were hub centric till i took the front off and the cetric pice had failed im yet to replace but fairly sure this issue was there b4 thre spacers be so happy if its the spacers!
    Feb 2009
    Aberdeen
    2,621
    Failed? Sounds like you may have a culprit here. Take off the spacers and try again, pretty easy one to at least test.
    Hunt is over
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    How does it fail?...
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    Sorry for the essay...
    sometimes the chamfer around the base of the locating ring doesn't properly locate in the wheel because the spigot in the wheel has a different chamfer.
    I had this issue with HnR 8mm Hubcentric spacers. The chamfer around the base of the ring was 7mmx45° but the depth of the spigot in my wheels was slightly less than 7mm (I measured about 6.5mm with a calliper which meant that the face of the spacer could not sit flush to the wheel giving me wheel wobble. It wasn't an obvious misfit and i was completely unaware of it until i lay my wheel face down on the ground placed the spacer in the back of the wheel and stood on it. Because of the misfit i could rock the spacer around by changing the position of my bodyweight which is what was happening at 60mph - wheel wobble
    This is why i changed to a 10mm spacer that had a 5mmx45° chamfer at the base of the locating ring and problem was solved...
    Example picture:
    Here the picture is showing the requirement to fit over the locating lip on the wheel hub of your car as well as your wheel spigot depth
    I would guess that wheel wobble caused by a mis-fitting spacer would cause the hubcentric/locating ring to fail
    hope that helps
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Oct 2010
    108
    they failed in when i removed my wheels last the ring have snaped off the centre and was stuck or held in the wheel by the spigot ring and is now curently being centred by the taper of the bolt that hold the wheel
  1. Steering Wheel Wobble at 80mph?
    By tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th October 2009, 13:37
  2. Steering Wheel Wobble at High Speed (Wheels Balanced)
    By jomnhta in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2009, 14:02
  3. steering wheel wobble
    By gags100 in forum Classic Audi Forum
    Last Post: 17th April 2008, 23:11
  4. Wheel wobble!
    By jerz in forum TT/TT-S/TT-RS Forum
    Last Post: 18th September 2007, 12:16
  5. metal on metal sound and rear wheel wobble
    By ScoobyA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th April 2007, 00:36
