Sky InsuranceBadger5
Results 1 to 7 of 7
    Aug 2010
    bradford
    1,252
    just a quicky people
    can anyone recomend doin owt else before i torque the head up thanks.
    new water pump on damper, tenstioner, pistons in rods torqed up new oil pump an and pick up pipe sump on.
    water lines oil lines turbo and mani all bolted on to head.
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    blow your load into the cylinder.
    aids lubrication
    Reesy's Avatar
    East Sussex
    3,604
    Quote Originally Posted by s3gazz View Post
    Head Gasket?
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,357
    Cup of tea first I reckon Gaz
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    N/a head gasket for extra cr?
    beachbuggy's Avatar
    Surrey
    1,744
    Unless you had the block sonically cleaned, blow the oil and water galleries with compressed air to ensure no crap or debris has got in
    Aug 2010
    bradford
    1,252
    Thanks guys Andrew did my head dan and cleaned it in the bath thingy lol head gasket on at min iv packed up for night and back on it Tomoz ill fill the cams he's up with oil when it's torqued up.
    need to wrap down pipe, put timing belt onto head cog, set timing, torque head down, get a tip and DV, seal sump, oil and water line to block, get a phenolic gasket, fill oil and coolant, sort cat out to fit Milltek and wrap my lambda sensor with somate as its ryt next to mani.
    dont no how Ro do trimming so need to get Someone that nose what there doin.
    or and fill turbo with oil first
  1. Replies: 12
    Last Post: 14th May 2010, 19:44
  2. Just a quickie.....
    By Jack-A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2009, 23:48
  3. just a quickie
    By peakey in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2009, 19:36
  4. Just a quickie - another start up question
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2007, 21:52
  5. just a quickie
    By mac1403 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd May 2006, 17:33
