Badger5Sky Insurance
Results 1 to 8 of 8
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    879
    Add Vex182 on Facebook
    Post Longer pipe needed from charge pipe to DV - suggestions?
    Not driven my car for 6 weeks due to being really busy at work, thought today I would look unto the issue I have of my Badger5 TIP bending at the bottom. Currently got a "Creations Motorsport" DV pipe from the charge pipe and it seems to be a bit short, its pulling on the DV and causing a bend in the bottom of the TIP. Not much use with my Badger5 TIP lol. My current one is 26cm from the longest points, anyone else got a longer one?
    Thats the amount extra I need to stop the TIP frm bending.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    use an alloy joiner and a piece of same diameter pipe.
    never heard or seen of this though
    perhaps trim the bottom part of your tip a cm or 2
    Vex182's Avatar
    Apr 2012
    Hinckley
    879
    I know it seems a bit odd, I really don't remember cutting the pipe down before I fitted it the first time. The TIP could be trimmed a little but there is not much to take off and yeh that's all fitted corectly too. Could anyone give a quick measurement of there DV pipe? Thanks!
    sam4191's Avatar
    If In doubt, Flat out!
    Feb 2009
    Highcliffe, Dorset
    399
    I know this will be no help to you, but I bought a Turbo-Charge pipe hose from these guys the other day and it doesn't fit the charge pipe. (if it does, its rediculously tight) Haven't heard good things about them either.
    Vex182's Avatar
    Apr 2012
    Hinckley
    879
    I got the pair of pipes (DV and N75) from them and had no issues with fitment of them at all, was about a year ago, only now have I noticed that the DV is to short and I can't find my original one to compare the length.
    Vex182's Avatar
    Apr 2012
    Hinckley
    879
    Can anyone please measure the original DV to charge pipe?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    From the bend approx 240mm
    Vex182's Avatar
    Apr 2012
    Hinckley
    879
    Cheers, is that from the inner bend like closest to the DV?
  1. Size of boost pipe from turbo to charge pipe
    By gez in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2011, 20:50
  2. S3 charge pipe
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2010, 17:31
  3. oil leak from turbo pipe
    By john24susan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2008, 09:57
  4. S3 Charge Pipe
    By S3_Jack in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2007, 14:17
  5. Oil in Turbo charge pipe
    By rob1380 in forum Diesel forum
    Last Post: 31st May 2007, 18:21
