Volks AutosBadger5
Page 2 of 25 FirstFirst 12345678912 ... LastLast
Results 41 to 80 of 975
Like Tree147Likes
Thread: MIGGZ's A3 1.8t - The all rounder build thread
  1. #41
    nanananananananan BATMAN
    May 2012
    JHB, South Africa
    1,087
    Add MIGGZ on Facebook
    some acceleration videos
    now we know how much you love videos, here is some random ones i took last night.
    dont worry about the brake pad wear light its from the 6pot upgrade i just need to fix the light still
    1st one up is stand still to 4th gear
    unitronic stg 2 audi a3 1 8t 1st to 4th gear - YouTube
    next up is the glowshift showing off 1.5bar boost from 3500rpm
    unitronic stage 2 audi a3 1 8t glowshift gauges - YouTube
    the next one is 3rd gear to 5th gear pull
    unitronic stage 2 audi A3 1 8t 3rd to 5th gear pull - YouTube
    enjoy!
    Dj Vegas likes this.
    My rides thread : http://www.audi-sport.net/vb/a3-s3-f...t-journey.html
    Quote Originally Posted by Paradox1 View Post
    Healthy??? no,no,noooo
    Mine is healthy
    yours is on steriods!!!
  3. #42
    May 2012
    JHB, South Africa
    1,087
    Miggz A3 1.8t the journey
    So did some work on my car last week, did a full sump service including pick up.
    Changed my filter for a nice fresh new one
    Then while that was all open decided to vent my catch can to atmosphere instead of it going back into the tip like it was before
    Then stripped the rear to rubberize the boot, but while that was open I have not put the rears back.
    I thinking of bracing the rear but need ideas thou
    Mine is healthy
  4. #43
    May 2012
    JHB, South Africa
    1,087
    Organized some bridgstone semis for like £12 each, 2 have 3 to 4 mm before the wear line, 2 are on the wear line and 1 is like 2mm before wear line. Seeing as its the 1st time I'm gona be using semis thought I would not miss the chance on this deal
    Got my mate Magster to make me 5mm hub centered spacers for the front. Iv already got 10mm for the rear (hub centric)
    Just need to source wheel bolts. Which has been such a ball ache so far.
    Enjoy! Thanks for looking
    Mine is healthy
  5. #44
    May 2012
    JHB, South Africa
    1,087
    Which gauge would you choose?
    I'm torn between which Air/fuel Ratio gauge to choose from. Both are standalone wideband gauges with their own lambda and control unit!
    Mine is healthy
  6. #45
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,389
    Hmmmm
    tough one mate. I THINK I'd go for the top one with the needle, the lower one is similar to my AEM Uego, it's its a. It too busy colour wise for me.
    Semis look great for that money! What size?
  7. #46
    May 2012
    JHB, South Africa
    1,087
    My SO said the same she likes the top one as it matches the other gauges. Ill put up the write up now of it.
    The semis are bridgestone 225/40/17
    Mine is healthy
  8. #47
    May 2012
    JHB, South Africa
    1,087
    GlowShift’s Elite 10 Color Series Wideband Air/Fuel Ratio Gauge is an ultra-high performance gauge that allows you to monitor, as well as tune your vehicle’s air to fuel ratio, resulting in multiple benefits. These benefits include maximized power and engine performance, reduced emissions, and higher fuel economy by allowing you to carefully map out your vehicle’s air to fuel ratios throughout the range of RPM and manifold pressure which results in maximized power output. This standalone wideband air to fuel ratio gauge reads and displays your vehicle's air/fuel ratio, with unparalleled accuracy, from 10.0 to 20.0 AFR with the included Bosch LSU 4.9 wideband oxygen sensor.
    This Elite 10 Color Series Wideband Air/Fuel Ratio Gauge includes a Bosch LSU 4.9 wideband oxygen sensor, unlike many other wideband air/fuel gauges that utilize the older LSU 4.2 sensor. This 4.9 LSU wideband o2 sensor is installed to your vehicle’s exhaust with the included weld in bung, and the 13 foot sensor wire utilizes a modular connector to securely connect to the included wideband control box. The included power wires and wire harnesses are completely plug and play, and securely snap into the wideband control box, as well as the back of the gauge with modular connectors.
    GlowShift’s 2 1/16th inch (52mm) Wideband Air/Fuel Ratio Gauge offers some incredible features that include an easy to read analog readout, a peak recall function, programmable high and low warning functions, stepper motor technology, as well as 10 color through dial LED lighting, a self-calibration mode, and a low profile magnified tinted lens with an illuminated red needle. The adjustable high and low warning functions will alert you visually or with an optional audible tone, ensuring your vehicle’s air/fuel mixture is running at optimum levels. The included stepper motor ensures all needle movement is incredibly smooth and all gauge readings are extremely accurate. GlowShift’s 10 color through dial lighting lets you match your stock gauges or add a unique look to your vehicle’s interior. With the included color recall feature, you never have to worry about resetting the gauge to your preferred color every time your vehicle is turned on.
    GlowShift gives a 0 to 5 volt digital output with this Wideband Air/Fuel Gauge’s controller, allowing you to connect it to virtually any data logging or engine management system.
    NOTE:The included Bosch 4.9 LSU Wideband o2 Sensor includes Bosch’s 30 day manufacturer’s warranty. GlowShift does not warranty this o2 sensor after that 30 day time frame.
    Elite 10 Color Wideband A/F Gauge:
    2 1/16th Inch Black Face with Magnified Tinted Lens
    Analog Display Reads from 10.0 to 20.0 AFR
    Digital 12 Volt Wideband Contoller Unit with Data Logging Output
    Bosch LSU 4.9 Wideband Oxygen Sensor
    13 Foot Sensor Wire Harness
    6 Foot Control Unit to Gauge Wire Harness
    5 Foot Power Wire Harness
    Weld-In Sensor Bung
    Mounting and Installation Hardware
    Free Lifetime Technical Support
    One Year Liminted Warranty
    Linear Data Logging Outputs:
    Linear Narrowband Output: 0 to 1 Volt
    Linear Wideband Output: 0 to 5 Volts
    Sorry for all the reading
    Mine is healthy
  9. #48
    May 2012
    JHB, South Africa
    1,087
    so been a bit busy this december with work so not much was done except for ideas and planning.
    iv decided not to go for a AIR/FUEL ratio gauge as of yet, as i have other things that need my money spent on lol
    iv got 3 sets of wheels:
    16" oem wheels
    17" porsche twists with bridgestone semis ( im still busy with the refurb on the wheels and deciding what colour)
    18" SSW wheels which are my everyday wheels
    iv got spacers for the wheels but it is such a mission to keep changing wheels, bolts and spacers. So after some homework decided to look into a stud conversion with open lugs so that 1 nut fits all the rims.
    I have spoken to bill and will be ordering a set of studs from him, the reason i will be going thru badger5 is what bill sells to his customers he would use on his own car and for me personally thats trust.
    this morning i orderd a set of blue anodized lug nuts off ebay to match my calipers lol and i like that they 48mm long so it will have that race car look
    anyway thats it for now
    Mine is healthy
  10. #49
    May 2012
    JHB, South Africa
    1,087
    So good and bad news.....
    Good news:
    My new lug nuts arrived yesterday.
    I was expecting it to be a brighter blue. O well
    Bad news:
    the lugnuts are 48mm long so I was hoping it would clear the holes for the bolts, it does, but when you put the socket in to tighten and loosen the nuts the socket touches the rims and you can't get a grip of the nut! Fml
    Now I'm gona have to get a quote on making the stud holes 3mm wider!
    Mine is healthy
  11. #50
    May 2012
    JHB, South Africa
    1,087
    so i got me another set of semis, this pair went up for sale with rims and 75%+ tred left for 60pound so could not say no to them
    im becoming such SEMI whore!
    Mine is healthy
  12. #51
    Gizmo20VT's Avatar
    Jun 2012
    289
    Some good progress, Just dont nurse those semi's
    MIGGZ likes this.
  13. #52
    May 2012
    JHB, South Africa
    1,087
    Quote Originally Posted by Gizmo20VT View Post
    bwaaaahahahahahahaha i was laughing as i was typing it wondering if anyone was gona get it lol
    legend dude
    Mine is healthy
  14. #53
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,389
    I'll comment in your thread dude, apologies for not doing so previously. It's a thousand times more entertaining than all the 'which wheels' and 'what FMIC' threads that pop up
    What I don't understand about your wheel problem, is what size are your current studs? and why can't you just get longer ones of the same? surely they're all M14, so whatever size nuts you have currently can just be replicated surely?>
    those bridgestone semis look pretty cool too, don't see them over here much at all !
  15. #54
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,389
    oh, and just for you, 54....
  16. #55
    May 2012
    JHB, South Africa
    1,087
    Lmao thanks dude!
    I want to do a stud conversion and use lug nuts to tighten the wheels, as I have 16 wheels, 4 different sets, I have 2 different sets of spaces, now instead of running with like 60 or 80 different bolts use 1 set of lug nuts for all applications. Now the studs I got today are 90mm so I can run up to a 30mm spacer if need be. But that's a lot of strain for the studs so max will be 20mm, its a open end lug nut so any spacer of wheel stud will work!
    But got that sorted today with the issue I was having with my 18s with the lug nut holes not being big enough. Went for a quote this morn and they will be sent in next week, then ill send the wheels in for powdercoating same time
    Mine is healthy
  17. #56
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,389
    Sorted, I understood the reasons for wanting studs, just didn't know why some sockets would fit inside the current wheels and others not.
    I know what you mean though, I also have 4 sets of wheels, 2 sets of OE wheels (S3's and TT comps) and 2 sets of aftermarket wheels, so need a set of radius bolts and a set of taper bolts. In an ideal world I'd have all aftermarket wheels and studs / nuts to make things simple.
  18. #57
    May 2012
    JHB, South Africa
    1,087
    All 4 use cone studs so that's sweet just the 18s used a turner bolt instead of a hex head bolt so a longer hex would not fit with out opening the stud hole, that's why I went for a 48mm nut thinking it will clear it fine, which it did, but the spoke is a bit to thick around the stud hole so the socket would not fit, but that is getting sorted now lol
    Mine is healthy
  19. #58
    Dec 2012
    South Africa
    6
    yeah its looking good dude, cant want to see the lugs on
  20. #59
    May 2012
    JHB, South Africa
    1,087
    thannks duuuuuuuude
    Mine is healthy
  21. #60
    Dec 2012
    South Africa
    6
    Its looking to good!! good more my boi
  22. #61
    May 2012
    JHB, South Africa
    1,087
    got my new studs yesterday, they a little long lol 90mm
    but its the only size i could find longer then 40mm
    so going to be fitting them once i send my wheels in to be drilled then powder coat! just need to decide on colour
    Mine is healthy
  23. #62
    Oct 2012
    South Africa
    268
    Great progress!
  24. #63
    May 2012
    JHB, South Africa
    1,087
    Quote Originally Posted by Sidey View Post
    Great progress!
    thanks dude
    Mine is healthy
  25. #64
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,389
    Do they have an allen key in the end to tighten them in? I assume you fit with threadlock then you're done?
    What did the full set of 20 cost you dude? I've been meaning to do this for a LOOOOOOOOONG time.
  26. #65
    May 2012
    JHB, South Africa
    1,087
    unfortunately they dont so i need to do it the hard way lol
    yeah i got the thread lock as well when i take my wheels off to send them in ill do the studs
    they cost me 39quid with thread lock
    but bill could get 60mm studs for like 30 i think
    Mine is healthy
  27. #66
    Sixty 9 GP's Avatar
    Dec 2012
    South Africa
    45
    This thread has EPIC written all over it!
    and im so glad i twisted your arm into getting an 8L again ;-)
  28. #67
    May 2012
    JHB, South Africa
    1,087
    Hahahahah thanks again bud
    Mine is healthy
  29. #68
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,389
    OI, MIGGZ!!!!!
    I KNOW you went somewhere for mappy type changes and stuff recently, where's the update
  30. #69
    May 2012
    JHB, South Africa
    1,087
    Hahahah ok ok ill do a little write up now.
    So the other night I decided to do some logs on my car after reading everyone doing their maf logs.
    I did mine and I only got 146.3g/s, now I was talking to prawn via whatsapp stressing my ass off thinking my car is stuffed. While running logs I still had a TLGP with a ford focus st (2.5t) and a golf 6 ED35 (k04). The G6 stayed till over 200km/h then we ran out of road and the ST got a hiding of his life.
    So stressing the whole time and everyone is saying my MAF might be on the way out I went pricing around for Bosch ones and all that.
    On tuesday I went to my turner to have a look at things and the only thing he could see was that at 1.7bar my injectors are at 90%.
    Not to stressed about that thou.
    So I asked about my maf readings and he said I don't need to worry, so I got even more stressed saying that the oaks in england are getting 190g/s on stage 1 cars. Then he tuned me, " dude what altitude are they at vs us? And the most iv seen on a 1.8t k03s is 154g/s"
    Then I asked nick if the altitude sorry could be right and he asked what is jhb's altitude and when I said 1834m he nearly died asking if we f#*king mountain goats lol
    So while my car was there I asked him to map me some left foot braking. I have always used left/foot and heal n toe but with the drive by wire it threw me off completely making me blip into a corner and slowly power out instead of using the brakes to power me out like I do on the bikes.
    Mine is healthy
  31. #70
    May 2012
    JHB, South Africa
    1,087
    Took a picture of the temp yesterday or the day before just to prove how hot it is here
    Was in a good mood yesterday and decided to do some work on my car lol
    * cleaned calipers + wheel arches
    * fixed my low brake pad warning light
    * removed front bumper cleaned intercooler and radiator
    * replaced my WMI pump screws and checked for leaks or wear
    * cleaned out my WMI filter
    * serviced my Forge 008
    * fitted my seats, amps and sound back
    My Hover craft
    Mine is healthy
  32. #71
    May 2012
    JHB, South Africa
    1,087
    so im thinking of swapping my SSW wheels for these ones, i love the look of them and when i bought mine these were not available.
    i wont be using those profile tyres ill be using my own tyres.
    whats the opinion on them?
    also iv found a set of S3 rears, disks and lines for 66quid so im waiting for my mate to part with them then ill be fitting them. also coming at such good timing as my disks and pads have seen better days
    Mine is healthy
  33. #72
    May 2012
    JHB, South Africa
    1,087
    so i went last night to do a test fit on those wheels, it looked so much better on my mates Jetta not the audi thou it looks huge.
    if i was going for that whole stance look it would have been epic as they 8j and with a 215/35 tyre there would be epic stretch!
    his looked pretty awesome with mine on
    Mine is healthy
  34. #73
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,389
    hmmmmmmmmmmmm, tough call Miggz, but I think your black wheels look better.
    Car looks lovely too, so cool in white!
  35. #74
    May 2012
    JHB, South Africa
    1,087
    thanks mr nick, i agree i like my ones more so we swapped back last night
    Mine is healthy
  36. #75
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by MIGGZ View Post
    Haha i was just going to say, did he say no swaps back....
  37. #76
    May 2012
    JHB, South Africa
    1,087
    i pulled a good move we only swapped two so if he said no i would be running 2 black 2 silver lol
    Mine is healthy
  38. #77
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,790
    Nice work on the car mate! Deffo the black wheels look better
    <Jay A3 build thread>
    241bhp K03s - R Tech
  39. #78
    May 2012
    JHB, South Africa
    1,087
    Quote Originally Posted by Jay A3 View Post
    thanks mate, agree hey. when i get a little extra cash in im sending them in to get the holes opened up more to fit my stud and nut conversion then going to powdercoat the wheels. thinking a dark grey or titanium
    Mine is healthy
  40. #79
    May 2012
    JHB, South Africa
    1,087
    right, so these are the colours i had in mind
    Mine is healthy
  41. #80
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,790
    Sounds good mate! pics as soon as they are done!
    Edit: Curse you! uploaded some pics when i was posting haha
  1. Frenchmans A3 daily/ track all rounder
    By frenchman in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2014, 13:51
  2. The all-new RS 4 Avant
    By ScottD3 in forum General Chat
    Last Post: 1st September 2012, 03:37
  3. Recommended all rounder tyres for a S3?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2012, 23:52
  4. The ALL NEW German Car Show 2011
    By germancarshow in forum Major UK Events
    Last Post: 11th May 2011, 23:58
  5. The Kingfisher A3 build thread (image heavy)
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2010, 18:53
