Volks AutosJMB Retrofits
Results 1 to 7 of 7
    Aug 2010
    21
    driveshafts S3/A3 8L
    does anyone know if they are the same driveshafts? or if they fit both cars...
    BENJAMIN's Avatar
    Mar 2011
    472
    NSF S3 driveshaft will fit an a3 if its fitted with the 6 speed box. Other than that, no. This is presuming we're not talking about an a3 Quattro though.
    Aug 2010
    21
    no.. just a front wheel drive a3.. and its only 5 speed..
    so thanks for the info.
    Pat
    Dec 2006
    512
    I got a set of s3 ones if interested
    2002 S3, Project 400, New Build In Progress, I.E 2.0 stoker kit, Big Port AGU Head, Ferrea Valves retainers, springs etc, GT30 compact, Pagparts Manifold, AH Front Mount Version 2, Genesis 550cc Injectors, 044 Fuel pump in I.E Surge Tank, Revo Stage 3 Software, Porsche Brakes, work in progress
    Aug 2010
    21
    will S3 driveshafts (passenger side) actually fit a 8l A3?
    olethalb's Avatar
    Aug 2012
    314
    5 speed are not interchangeable with 6 speed.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,388
    no, they won't fit mate.
    Also, what age is your car?
    Pre July 98 will have 100mm flanges and ball / cage CV's, post july 98 will have 108mm tri roller inner joints.
    They did a very mild facelift in July 98 which included the revised door handles, slightly different shifter mech, and I believe this is when the CV's where changed as well.
  1. ABS & driveshaft removal - B5 quattro
    By Griffter in forum Handling
    Last Post: 29th September 2006, 08:23
  2. A3 1.8ts 2001 driveshaft diameter.
    By ben_turbo1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2006, 11:00
  3. 1998 A3 1.8T (2wd) Driveshaft Diameters?
    By Tallpaul in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2006, 16:36
  4. URGENT - AUDI A4 DRIVESHAFT QUESTION
    By ScottyBoy in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th July 2006, 17:55
  5. Driveshafts
    By steady in forum Handling
    Last Post: 30th December 2004, 12:29
