EM TuningVolks Autos
Results 1 to 8 of 8
    Jul 2008
    55
    Coolant Thermostat Symptoms....
    Hi guys
    Im the proud new owner of a 1.8T Sport.
    The temp gauge doesn't work, I scanned it and its come up as the coolant temp sensor.
    Could this be causing the can to run a bit lumpy? Its the only code that came up.
    Thanks in advance
    Darren4's Avatar
    Feb 2009
    Surrey
    185
    Having that gone will meaning the engine will always think its cold and use more petrol as a result. Get it changed and you should see a slight increase in mpg
    Audi S3 01 Facelift Ming Blue | Forge 007p | Jetex Air Filter | BlueFlame Cat Back | 6K HIDS | Tints All Round | LCR Splitter | Pure Stealth
    Jul 2008
    55
    Thanks Darren.
    Its booked in for the coil pack recall on the 4th. Its running lumpy so that maybe it.
    Any idea on the price of the coolant thermostat at TPS?
    Jun 2012
    Essex
    197
    Was only searching up on this earlier, mine does exactly the same, despite giving mine a hammering (private road of course) it still reads at the lowest. Will get a new one on order tomorrow....cheers guys
    Jul 2008
    55
    Munch, is yours running rough, a bit lumpy like it has a misfire?
    Nov 2011
    Sturminster Newton
    190
    order one up only like a £10 if its not that atleast you know you got a new sensor in there.
    A3 1.8TQS Minge blue
    Mods: AP coilovers, Strut Brace, Merc wheels, S3 brakes, hopefully going BT soon
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    I think you mean the Coolant Temperature Sensor - it is not the same as the Thermostat which you mentioned in the title. The thermostart from TPS with a new seal is somewhere under £20. I don't know about the cost of CTS maybe <£15.
    When it comes to getting parts like this for your car you can get equivalent/cheap parts from ECP/GSF etc. however the general consensus of opinion is you get what you pay for - you'll get a few people who will tell you that cheap ebay CTSs or stats will be fine but from what I can tell most people end up being of the opinion "buy cheap buy twice" - so spend a few quid more and go to the dealer or better still TPS.
    When I got my S3, I changed the CTS, stat with OEM parts and had the coolant system flushed and filled with a new load of VAG G12+++++++++++
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Jun 2012
    Essex
    197
    Quote Originally Posted by mike.c1979 View Post
    Its not misfiring, but missus has said recently that when she pulls away its sluggish. Have also noticed on idle, the revs spike and drop, o ly for a split second, but its noticable.
    ive got no receipts to say its ever been replaced, so may replace the sensor and thermostat whilst I'm at it.
  1. Symptoms of thermostat gone?
    By antnee in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2012, 00:09
  2. Thermostat and Coolant( not troubleshooting)
    By A3AH in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2012, 12:18
  3. replaced thermostat - coolant now not circulating.
    By casiodan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th January 2011, 13:19
  4. Necessary to drain the coolant system when changing thermostat?
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2010, 13:25
  5. Coolant loss changing Thermostat?????
    By S3 Dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2007, 22:43
