Right, I had sussed that I had to use the Central locking option not convenience and have followed the instructions to pair keys including clearing all old onmes on channel '00'. My problem is that I change the value to 2 and test then save but cannot get either of my keys to pair. I have done it using lock then tried unlock buttons on both remotes that I know were working before I messed it up. Both keys start the car no problem but I have also noticed that when I lock the car via the door lock the alarm does not arm either. Is that because I am not using the remote? I did have a fault in the cluster that I think I should not have cleared. Here are 2 logs, one from before clearing fault codes and one after I got home from after realising they werent working when I went out:-
1:-
Sunday,25,November,2012,10:53:37:31506
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8LX31204543
Address 01: Engine Labels: 06A-906-032-BAM.lbl
Part No: 8N0 906 018 BH
Component: 1.8L R4/5VT 0001
Coding: 10710
Shop #: WSC 02629
VCID: 78F469C358A859D8195
WAUZZZ8LX31204543 AUZ7Z0B2120937
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Part No: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 01236
VCID: 3E78BFDB3A0CA7E8139
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 L
Component: A3 KLIMAAUTOMAT 0105
Coding: 00041
Shop #: WSC 01236
VCID: 316294E7FB5248909EB
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 L
Component: Airbag Front+Seite 7008
Coding: 01104
Shop #: WSC 01236
VCID: 4796DA3F65D6E620A0F
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 01236
VCID: 2F66929FED665E6088F
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 980 R
Component: KOMBI+WEGFAHRS. VDO D10
Coding: 01444
Shop #: WSC 00402
VCID: 4280CB2B4EF4C308771
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 C
Component: HALDEX LSC ECC 0010
VCID: 204461A3A0B8F118015
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 00033
Shop #: WSC 00652
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00953
VCID: E0C4A1A360383118C15
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00014
Shop #: WSC 01236
VCID: E5CAB0B77F1A5430323
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8L0 035 195 H
Component: symphony II NP2 0151
Coding: 00205
Shop #: WSC 00757
VCID: 336E9EEF014E7A80EC7
Address 76: Park Assist Labels: 4B0-919-283.lbl
Part No: 4B0 919 283
Component: Parkingsystem A3 RDW D18
Coding: 00103
Shop #: WSC 01236
VCID: E6C8B7BB821C5F283B9
2:-
Sunday,25,November,2012,18:58:30:31506
Coding: 10710
Shop #: WSC 02629
Coding: 18448
Shop #: WSC 01236
Coding: 00041
Shop #: WSC 01236
Coding: 01104
Shop #: WSC 01236
1 Fault Found:
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
32-10 - Resistance too High - Intermittent
Coding: 01002
Shop #: WSC 01236
Coding: 01444
Shop #: WSC 00402
Coding: 00032
Shop #: WSC 00652
Coding: 00001
Shop #: WSC 00953
Coding: 00014
Shop #: WSC 01236
Coding: 00205
Shop #: WSC 00757
Coding: 00103
Shop #: WSC 01236
