EM TuningSky Insurance
    Dec 2011
    Bedfordshire
    127
    Help with a fault code???
    I scanned my car today and came up with this fault code
    16795
    secondry air
    injection system
    incorrect flow detected
    p0411
    Anyone know what it means?? Thanks
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    829
    Add Vex182 on Facebook
    16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected
    Possible Symptoms
    Malfunction Indicator Light (MIL) ON
    Possible Causes
    Fuel Pump Relay (J17) faulty
    Hoses/Pipes to/between Components faulty/clogged
    Secondary Air Injection Pump (V101) faulty
    Secondary Air Injection Pump Relay (J299) faulty
    Secondary Air Injection Solenoid Valve (N112) faulty
    Possible Solutions
    Check Fuel Pump Relay (J17)
    Check Hoses/Pipes to/between Components
    Check Secondary Air Injection Hoses/Pipes for Carbonization
    Check Secondary Air Injection Pump (V101)
    Check Secondary Air Injection Pump Relay (J299)
    Check Secondary Air Injection Solenoid Valve (N112)
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
  1. Need some help with a fault code please?
    By DaveA3-TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2011, 09:39
  2. I need some help with some fault codes please
    Last Post: 19th May 2011, 16:14
  3. Help with recorded fault code
    By Damian s in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2007, 18:33
  4. helps with some vag codes!!!!!
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th November 2005, 19:46
  5. Help with a part code please?
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2004, 16:48
